Old 18-03-2009, 02:23 AM   #1 (permalink)
Default how to use subtitle in 6-1 dvd
recently i have bought a dvd which is 6-1 ...now i have downloaded sub title for them but i am not be able to play them as they are meant to be..i think they are generally for 700 mb rip but i am having files of different size like one 0.99 mb file has 1 movie full and other movie in half and its completed in next part of 275 mb now plz tell me how to use subtitle so that it can be played acc to scene
ashishstillthere is offline
Old 18-03-2009, 04:58 AM   #2 (permalink)
silentFOX
mittyr's Avatar
Default Re: how to use subtitle in 6-1 dvd
You will need "DirectVobsub"(its comes in CODEC PACKS - eg: CCCP) or "VLC Player" or any video player that can handle external subtitles.
Then name the subtitle file excatly as the movie file. Once you start the movie, the subtitles will be automatically loaded incase of "DirectVodsub" - it has to be loaded manually in "VLC Player".
Now, once its starts check if its in sync with the movie. If not you will have to sync it manually. You can use "Subtitle Workshop" or "Submagic" for this. (Syncing can take hours if you are lucky just a few minutes)
Posted again:
Forgot to mention, you will have to play the *.vob files one by one than "Autoplay" the DVD. So better copy to PC and move the subtitles to the same folder.
mittyr is offline
Old 18-03-2009, 10:00 PM   #3 (permalink)
i am using vlc player n my problem is that sub title isnt playing according to dialogue...n i dont know how to usesubtitle workshop
Old 19-03-2009, 05:28 AM   #4 (permalink)
silentFOX
mittyr's Avatar
If you just wanna watch it, here's the shortcut for adjusting "time delay" in VLC Player.
Ctrl+H - Increase subtitle delay by 50ms
Ctrl+J - Decrease subtitle delay by 50ms
If you wanna edit it "Submagic" would be much easier.
http://www.softpedia.com/progDownloa...oad-48060.html
If you need tips in editing, do ask
mittyr is offline
