Old 17-03-2009, 05:26 PM   #1 (permalink)
Call me D_J!
Disc_Junkie's Avatar
Default WLL Internet problem.
I am facing a problem nowadays. I have got WLL Internet. My UPS doesn't give enough backup for which when power fails I am unable to shutdown properly. When I restart the WLL fails to establish a connection and makes a connection after much time. Why does this happens and how can I correct the problem?
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Old 22-03-2009, 02:16 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: WLL Internet problem.
please explain in details are what is WLL ?? is it Wireless in Local loop, if it is, then what hardware and type of connectivity cable do you using ??
What is your OS and what is your PC Config ?
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 22-03-2009, 02:25 PM   #3 (permalink)
Call me D_J!
^^ Problem solved dude. Thanks for your comments.
