Old 15-03-2009, 02:17 PM   #1 (permalink)
Default restarting problem
hi guys...I hv a problm ,can u help me???one of my frnd's computer had two 128mb ddr1 ram...today I installed a 512mb ram n started the pc..it started as before n showed that it has 632mb of ram...system was very slow,so I formatted the c drive.when installation completed the windows restarted n went on restarting after that...I replaced the original rams but no improve...it shows the msg that windows detected change in hardware or software...can u tell me wht cud b the possible reason n how to solve that???plz reply as soon as possible...
BibhuDatta is offline
Old 15-03-2009, 06:04 PM   #2 (permalink)
gkbhat.blogspot.com
Default Re: restarting problem
At what stage did the message flash up?
blogging at http://gkbhat.blogspot.com
gk2k is offline
Old 15-03-2009, 10:33 PM   #3 (permalink)
silentFOX
mittyr's Avatar
Did you try taking out the old sticks & put in just 512MB Stick ??
RAM Specs??
mittyr is offline
Old 15-03-2009, 10:49 PM   #4 (permalink)
What type of Ram module are you talking about that you inserted? is it ddr1/2 ect.....
Eyes Only is offline
Old 16-03-2009, 12:24 AM   #5 (permalink)
a.k.a VipER
Ecstasy's Avatar
Try booting in safe mode then right click on my computer>Advanced>Start up and recovery> then uncheck on 'Automatic restart'.
I think that should work. Do let me know after you try this.
Originally Posted by shayanthebest View Post
I want to buy a new computer which can play 2-3 year old games at good resolutions. My budget is 5 to 6 lakhs. Please help
Ecstasy is offline
