Old 14-03-2009, 09:05 PM   #1 (permalink)
rohitshubham's Avatar
Post utorrent port not forwarded
hey
whatever port i try to forward in utorrent speed guide it shows error and so i am not able to get high speed of downloads it is around 3-5 kBp/s whereas it should be around 25-30kBp/s
plz help me.........(my network card is REALTEK RTL8139 on WINDOWS XP)
and on one of my friend's computer the utorrent shows downloading but downloading dosen't starts and is always 0.00%
and yes what do the seeds and peer refer to???????:roll:
thanks
rohitshubham is offline
Old 14-03-2009, 10:40 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: utorrent port not forwarded
Its not your network card of OS which needs some work, its the Router / ADSL modem which you are using needs the tweak, which is called Port Forwarding..
Read more -> http://portforward.com/
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 14-03-2009, 11:21 PM   #3 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Well,
wat router u have ? also, PF shud be supported by ur ISP too..
SEEDS: (SEEDERS) are those ppl (well, actually ppl with computers) that hv the full 100% of the product (software) and they upload (seed) for others (leechers) to share..
PEERS: Seeders (ppl having the complete 100% of the s.ware)+Leechers=Peers..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 15-03-2009, 12:45 PM   #4 (permalink)
i am using sify broadband without any modem (i don't know as there is only network card in my pc which is connected via lan) and the ports used to worked perfectly until i formatted my computer and installed sp3
Old 15-03-2009, 12:53 PM   #5 (permalink)
rajwansh2003's Avatar
I am using ZTE EV-DO AC8700 800M BSNL which should i use? I did not find mine
Help me TO......
Anupam
rajwansh2003 is offline
Old 17-03-2009, 10:17 AM   #6 (permalink)
plz someone reply!!!!!!!!!
Posted again:
Last edited by rohitshubham; 17-03-2009 at 10:24 AM. Reason: Automerged Doublepost
Old 17-03-2009, 02:20 PM   #7 (permalink)
Rebooting
Sify does block Ports to throttle bit torrent traffic , hence as its pointed out by ashu888ashu888
its our ISP which is blocking the ports
rebooting
ChotoCheeta.com
Old 17-03-2009, 06:20 PM   #8 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
How about forcing encryption? that is supposed to fool the ISPs.
dheeraj_kumar is offline
