Old 11-03-2009, 11:13 PM   #1 (permalink)
kool's Avatar
Question how to write XP+SP3+DRIVER to single CD/DVD ??
Hi friends,
I've assembled PC, Its irritate me when i install XP then SP3 and then DRIVERS for all hardware!! So plzzz help me out... I've win_XP SP2 CD and separate SP3 and backup of all DRIVER via Driver Genius Pro v7. Now i want to make a single CD/DVD so it install itself all DRIVER of my system with XP SP3..
What software i needed to do all these?? and also tell me process step by step..
I've driver for intel(sound,video adapters, lan, ethernet), bluesoleil bluetooth, internal modem, internal netgear wi-fi, k-lite codec, autopatcher
Reply soon....
►► ◄◄ :smile::smile:
kool is online now
Old 11-03-2009, 11:45 PM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: how to write XP+SP3+DRIVER to single CD/DVD ??
Use nlite.........its free software....search it in google......or find it in DIGIT DVD's.......
Use it to bind all ur needs.........
if u face ny prblm while using it.....read documentaton........its very clear......!!!!
Posted again:
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
Last edited by krishnandu.sarkar; 11-03-2009 at 11:45 PM. Reason: Automerged Doublepost
krishnandu.sarkar is online now
Old 12-03-2009, 12:10 AM   #3 (permalink)
kool's Avatar
just now i've downloaded RVM windows updates of 29mb. how 2 add these xp cd?? and what abt DRiVER?
kool is online now
Old 12-03-2009, 06:28 PM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
nLite is pretty straightforward to use... if you have any trouble using it, go to http://unattended.msfn.org
dheeraj_kumar is offline
Old 13-03-2009, 01:10 PM   #5 (permalink)
Banned to Spam
Krazy Bluez's Avatar
Location: Look below...not under pants dumbo...use a GPS
Use the above mentioned site for help in nLite....
For drivers use Driverpacks.net
My DeviantART page now exists !!!
Krazy-Bluez.deviantart.com
Twitter: http://twitter.com/KrazyBluez
Krazy Bluez is offline
Old 13-03-2009, 08:18 PM   #6 (permalink)
I have integreted xp sp 2 and drivers using nlite which is working.Just after the realease of sp3, i read somewhere that if sp2 and sp3 are integreted updates like internet explorer 8,win media player 11 won't work because these updates are to be installed before installing sp3, but still i went ahead and created integreted sp2,sp3,win ply 11,& inte exp 8.Using this cd i am not able to use internet explorer.Have i made any mistake in integration or one really cannot integrate inte exp 8.
Hope i have not confused kool.
Posted again:
I have integrated xp sp 2 and drivers using nlite which is working.Just after the realease of sp3, i read somewhere that if sp2 and sp3 are integrated updates like internet explorer 8,win media player 11 won't work because these updates are to be installed before installing sp3, but still i went ahead and created integreted sp2,sp3,win ply 11,& inte exp 8.Using this cd i am not able to use internet explorer.Have i made any mistake in integration or one really cannot integrate inte exp 8.
yogisworld is offline
