Old 11-03-2009, 05:30 PM   #1 (permalink)
Default Req: help needed for removing multi boot options
guys please help on a topic
i hva C G E H partitions named
now previously i had vista instaled on G and i have XP on H rite now..
i formatted vista's drive that is G drive.
now i have just windows XP on my comp. on Drive H
i get still 3 Boot OPtions
earlier version of windows xp
vista(option which i deleted)
vista(option it comes from start but doesnt work)
i want to remove these options and have my Xp directly running without having to choose from the options
my boot options in xp says
;Warning: Boot.ini is used on Windows XP and earlier operating systems.
;Warning: Use BCDEDIT.exe to modify Windows Vista boot options.
[boot loader]
timeout=0
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOW S
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Professional" /NOEXECUTE=OPTIN /FASTDETECT
please help
Posted again:
thing is i dont have vista on my comp now, i deleted it, i hv xp only installed
i want to remove the boor options and have xp directly loaded without me having to select it
pls help
pls help
immortalguy is offline
Old 11-03-2009, 06:04 PM   #2 (permalink)
rhasta's Avatar
Default Re: Req: help needed for removing multi boot options
Type "msconfig" in RUN dialog box and goto "Boot.ini" tab and then you can change the desired thing. If you want to remove the corrupt/non-working entries, then click on "Check all boot paths" button.
rhasta is offline
Old 11-03-2009, 07:26 PM   #3 (permalink)
Exclamation Re: Req: help needed for removing multi boot options
what to type in boot .ini file???
i hv given the format in the post
please change it appropiately and post it back...
p.s. check boot paths it says paths are ok
still i see multiboot options and out of which only xp woks as earlier version of windows
helppppp
