Old 10-03-2009, 03:25 PM   #1 (permalink)
veddotcom's Avatar
Default Oracle 8i Installing Problem in XP
I Installed Oracle 8i in my PC using XP,Immediatly After Installing It was Running Fine, Means It was Accepting SCOTT TIGER, But After Restarting its not Accepting SCOTT-TIGER or SYSTEM-MANAGER, Why this is SO? What Should i Do now? I Installed Oracle 8.1.5.0.0 Personal Edition, I m Using Winxp with NTFS, I Searched in the Forum one Guy Said that 8i Doesn't Support to WINXP. Is it True? Should i go for 9i?
veddotcom is offline
Old 10-03-2009, 03:32 PM   #2 (permalink)
TheHumanBot's Avatar
Default Re: Oracle 8i Installing Problem in XP
i dont have answer to your question but i have a question
can you tell me what is 'i' in Oracle9i???
please its urgent for me
i googled it but didnt find any answer
TheHumanBot is offline
Old 10-03-2009, 03:41 PM   #3 (permalink)
veddotcom's Avatar
Its Another Later Version of Oracle, Thats it i know abt 9i As i m beginner Learnign ABC of DBMS.
Just Now I got This LINK, Where You Will Get Everythign About ORACLE
http://forums.oracle.com Check it.
Old 10-03-2009, 09:41 PM   #4 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
1. Run notepad
2. PAste this
@echo off
echo connect INTERNAL/ORACLE >%0.tmp
echo STARTUP OPEN >>%0.tmp
echo exit 8; >>%0.tmp
rem -- Run sql script --
sqlplus /nolog @%0.tmp
rem -- Cleanup --
del %0.tmp
start sqlplusw scott/tiger
exit
3. File > Save AS
4. Save in C Drive as Start_oracle.bat
5. Run this file each time and it should work
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 05-04-2009, 06:06 PM   #5 (permalink)
N3CrO..NiNj@**
i have oracle 9i setup of 3 cds
i tried to install them in windows vista and got an error of
jrew.exe file stoped working
and setup closes....
can anyone tell me why this is happening and how to solve this problem????
Posted again:
c2tarun is offline
Old 05-04-2009, 10:42 PM   #6 (permalink)
veddotcom's Avatar
Posted again:
Oracle 9i Doesn't Support VISTA, But Supports XP
Oracle 8i Doesn't Support VISTA Nor XP But Supports 2000
Oracle 8 Supports XP
Oracle 10g/11g Supports XP and VISTA Both
I read somewhere that few version of 10g Doesn't Run on VISTA
[I am Not 100% Sure, I told you by Googling abt Oracle]
