Old 04-03-2009, 12:09 PM   #1 (permalink)
Post Urgent : Trojan virus problem:
Im using a winows sp2 & a virus(expected trojan) has infected system 32 & other software files containg its self made .exe files..... which are present upto now even after complete harddisk format.
tell me wat i have to do to recover frm this & is their any tweak tat work through registry to banned all that .exe files.
reply soon.
thankx
Naughti is offline
Old 04-03-2009, 12:14 PM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Default Re: Urgent : Trojan virus problem:
reply soon.
thankx
Please search b4 posting.
Try KIS2009 or Avira...
Update to latest virus database and scan ur system
And, u want o ban all exe files??? What would u do there after...
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 04-03-2009, 12:30 PM   #3 (permalink)
Post Re: Urgent : Trojan virus problem:
i want to bann only that infected .exe files & first, if i stop them from registry then i can think to remove them.
Naughti is offline
Old 04-03-2009, 05:14 PM   #4 (permalink)
Wise Old Mouse
mrintech's Avatar
Go for a full scan with the following softwares:
* http://www.superantispyware.com/download.html
* http://www.emsisoft.com/en/software/free/
Also make sure that they are updated to latest definition files and go for Full System Scan.
Else
You can always try Online Scanning. Here's the list of best Online Scanners: http://mrintech.com/5-best-online-vi...rs-you-can-use
Problem will be solved
- MrinTech :)
mrintech is offline
Trojan virus problem Jafar Ali Software Q&A 12 02-03-2009 06:47 PM
Virus / trojan / malware problem. clayman Software Q&A 2 10-02-2009 02:19 PM
Worse than BSOD. Trojan or Virus. Urgent Help!! worried_alice Software Q&A 3 10-01-2007 05:23 PM
Some Virus/Trojan Problem...Wierd..!!! Dipen01 Software Q&A 7 01-03-2006 07:43 PM
Help ! Virus or Trojan Problem Hulo Software Q&A 3 18-10-2004 02:59 AM
