Old 07-06-2005, 01:04 PM   #1 (permalink)
Default How can I keep same format when I copy from PDF to WORD
Hi ! Whenever I copy some text from any text from PDF file & paste it in the Word document, it does not keep the source formatting. e.g., it changes the fonts from Times New Roman to Arial and also disturbed right or left allignment of text. Any suggestions will be greatly appreciated.
In the wait of some warm, positive and quick responses from digit community.
rana_punjabi_sardar is offline
Old 07-06-2005, 04:15 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
http://www.abbyy.com/
try this web site....
Choto Cheeta is offline
Old 07-06-2005, 04:17 PM   #3 (permalink)
Rebooting
get their PDF converter for free Eval... try that software.. if u know the proper way to use it then its 1 of the best..
Old 09-06-2005, 12:03 AM   #4 (permalink)
Thanx sourav
Old 09-06-2005, 12:25 AM   #5 (permalink)
get an pdf to word converter
sam8240 is offline
Old 09-06-2005, 02:24 PM   #6 (permalink)
ABBYY Fine Reader is the best in this case. I am using it to for quite some time and it is just great. It will keep the same formating as the original PDF file, line for line, word to word. It costs $300 to buy but its worth it. Try to find some trial version from cnet.com
super_i_man is offline
Old 09-06-2005, 03:09 PM   #7 (permalink)
Just Do It
Charley's Avatar
@Super so that keeps the entire document the same as when copied also, is it ??
Charley is offline
Old 09-06-2005, 10:37 PM   #8 (permalink)
Rebooting
achacko@dataone.in
but u know original author wanted to know this answar... & the benifit of have the
fact is u can just edit what ever u want.... add/remove.....
& yes most of the time abbyy does a very good job.... it make almost a xrox copy with edit function of MS word....
Old 10-06-2005, 01:44 AM   #9 (permalink)
SABER RIDER
maverickrohan's Avatar
One of the best PDF to Word Convertors...--->>>
DocSmartz
www.docsmartz.com
Its as good as viewing the orignal PDf albiet in Word
Find out Which is The Best Video Codec?....And how to encode video the right way..!!----->>>>> http://www.thinkdigit.com/forum/showthread.php?t=3908
maverickrohan is offline
- by gohan89
