Old 25-02-2009, 01:58 PM   #1 (permalink)
Default the setting?
Hi Guys,
I have got Windows XP Home Edition (SP2). I installed Audacity –1.2.2. I tried to record my voice with the Headphone Mic and tried to hear its output voice. But it did not work. How to solve it?
kumarn_2004 is offline
Old 25-02-2009, 02:20 PM   #2 (permalink)
damnbadman666
damngoodman999's Avatar
Default Re: the setting?
check with TEST HARDWARE on the audio panel & also make sure that all drivers r selected to the the soundblaster
damngoodman999 is offline
Old 25-02-2009, 03:55 PM   #3 (permalink)
I M A *STAR*
saqib_khan's Avatar
First check if ur headphone mic is working or not by sound recorder(in Accessories). Can u hear ur voice by recording in sound recorder?
Blogging at:
Technostarry
saqib_khan is offline
Old 26-02-2009, 12:49 PM   #4 (permalink)
Yes, you are right,my sound recorder does not work. Is there any way to uninstall the software and reinstall it with the help of my ORIGINAL Windows XP Home Edition(SP2)CD or via Internet. Your detailed reply,please.
Old 26-02-2009, 03:03 PM   #5 (permalink)
Amir.php's Avatar
Goto control pannel> sound and Audio devices.
Double click and open it.
Now click on voice tab.
In the voice recording Click on Test hardware> next for testing you hardware.
Follow the instructions here by speaking in your mike.
Also make sure that mike volume is set to full by clicking volume button.
After finishing try your software and sound recorder.
One thing more, You can not uninstall Sound recorder : it is windows property.
http://amirphp.wordpress.com
Amir.php is offline
Old 28-02-2009, 12:36 PM   #6 (permalink)
Hi Guys,
I did as per your instructions, but there was no output of voice. I think it is the sound recorder software problem. How to correct it?
Old 18-03-2009, 10:19 PM   #7 (permalink)
Call me D_J!
Disc_Junkie's Avatar
^^ maybe you put the wrong cable in the wrong port. fix it. If it doesn't work, I think your mic. is bad.
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Old 18-03-2009, 11:55 PM   #8 (permalink)
Originally Posted by kumarn_2004 View Post
Hi Guys,
Dude, You can't uninstall sound recorder. It comes in-built with the OS.. You should check your hardware..e.g. your microphone.. probably it's not working at all.. try another mic.. BoL..
delscarlet is offline
Old 20-03-2009, 12:27 PM   #9 (permalink)
Hi Guys,
I checked everything and understood that it was the Software problem not Hardware problem. Any way to correct it or can I use any other software for voice recording purpose other than the sound recorder on Windows XP Home Edition?
Old 20-03-2009, 02:32 PM   #10 (permalink)
Call me D_J!
1.Go to Control panel and check in the Voice Tab if your Sound Device is selected.
2. Slide up the volume bar in the recording tab in Volume Control.
3. Do this also in Audacity.
4. Other softwares you can try is AV Music Morpher or Nero Wave Editor
Old 21-03-2009, 09:31 AM   #11 (permalink)
Freak Beta 1
Dark Core's Avatar
It's a mess of driver problem, uninstall the driver and reinstall it, I suggest u to stick with Audacity coz it won't cost u a penny..
Twitter : www.twitter.com/arunselvakumar :twisted:
Facebook : www.facebook.com/arunselvakumar :evil:
Dark Core is offline
Old 21-03-2009, 04:35 PM   #12 (permalink)
Hi Guys,
It is O.K. Then, how to uninstall the Driver and reinstall it?
Setting up VPN Plasma_Snake QnA (read only) 2 08-04-2008 06:29 AM
Setting DC++ HUb deadpulse Software Q&A 1 19-02-2007 11:09 PM
Setting up IM??? prankie Mobiles and Tablets 7 19-05-2006 10:42 PM
setting up net vandit Open Source 1 24-09-2005 09:22 PM
Help 4 setting up New HDD and DVD ROM Thor QnA (read only) 11 30-10-2004 01:43 AM
- by gohan89
