Old 23-02-2009, 07:26 PM   #1 (permalink)
Unhappy Stop Error With Blue Background Plz Help
While Installing Windows Xp Sp3 From Boot Cd A Stop Error Is Showing With Blue Background And The Error Is "irql_not_less_or_equal" And Technical Information Is "***stop: 0x0000000a (0x015187da, 0x00000002, 0x00000000, 0x80815e8c" And Out Of 4 Hooks Of A Processor Fan, One Hook Has Broken I Bought Coolant Paste And Applied Then Also Problem Contineus Plz Help Me Asap
logon_munna is offline
Old 23-02-2009, 07:46 PM   #2 (permalink)
Default Re: Stop Error With Blue Background Plz Help
check this...
http://support.microsoft.com/kb/311564
is this the first time you installing windows on this hardware?
found this too:
http://www.tweaksforgeeks.com/IRQL_N..._OR_EQUAL.html
that broken CPU heat sink hook actually might be the culprit here...
6laz3r is offline
"Windows XP Blue Screen of Death STOP Codes" rhitwick Tutorials 6 09-08-2008 01:50 AM
Restore the blue background look and remove password asking anubhavj1 Software Q&A 8 09-06-2008 08:51 PM
windows 'stop' error purujitb Software Q&A 27 20-02-2007 11:00 AM
win xp installation stop error pfn_list_corrupt 0x0000004e patelsunilp Software Q&A 3 15-04-2005 12:05 AM
WinXP Pro- Blue Screen- STOP Error mark Software Q&A 9 30-10-2004 10:14 PM
- by gohan89
