Old 21-02-2009, 07:34 PM   #1 (permalink)
Smile Pen Drive Virus Solution
Hello Friends,
I knew that the all people really distrubed with PEN DRIVE virus which easily transfer in the pen drive/system. How to stop and delete before making changes in the system .
I can read many problems about that.
SOLUTION
Here the solution of all the query is AUTORUN EATER
Download the autorun eater
After installation
The start sound is great.It's really enjoying by you
The Scan Priority is High on the right click in the system tray icon.
Enjoy this software which is shield of the computer and the laptop.
It deny the virus which is automatically transfer in the system. Delete it.
For example: virus name snake.exe.vbs which directly going in the Windows directly. It stopped only by this software.
CAUTION:
It stop's only automatic active virus only
goel.suraj is offline
Old 21-02-2009, 07:44 PM   #2 (permalink)
thinking di9it'al
di9it's Avatar
Default Re: Pen Drive Virus Solution
Originally Posted by goel.suraj View Post
Hello Friends,
SOLUTION
After installation
CAUTION:
why dont u simply disable autorun?
My Rig:
AMD Athlon 5600+ @ 2.9GHz
Gigabyte M61PME-S2 MainBoard
Kingston 1x2GB 800MHz DDRII RAM
GFX Card : ???
HTC Touch Pro
di9it is offline
Old 21-02-2009, 07:53 PM   #3 (permalink)
Overlord v2.0
alexanderthegreat's Avatar
@goel.suraj:Wrong section! This should've been in Tutorials.
Also, I know a way without using 3rd party software.
The Only quote worth quoting: "E Loboa!!! What man???
Forum Rules:http://www.thinkdigit.com/forum/announcement.php?f=16&a=1
Disclaimer:No offence meant to ANYONE!
alexanderthegreat is offline
Old 21-02-2009, 08:09 PM   #4 (permalink)
Thumbs up Re: Pen Drive Virus Solution
Virus means unstoppable executable code.
If u disable the autorun.It only disable to auto start the pendrive not stopping the virus which is in the pen drive.This software not only stop virus but delete it.
If u have any doubt. Use this software and then give me the feedback.
Old 22-02-2009, 12:11 AM   #5 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
^^ Actually, disabling autorun stops running autorun.inf which runs the virus. So, if you disable autorun, you dont need this software at all, and you dont need to worry about autorun viruses anymore. You have the wrong notion of the method of execution of a virus.
and BTW There is a much better description in much better english at the original site:
http://oldmcdonald.wordpress.com/200...run-eater-v23/
dheeraj_kumar is offline
Old 22-02-2009, 04:50 PM   #6 (permalink)
thinking di9it'al
di9it's Avatar
Lightbulb Re: Pen Drive Virus Solution
U wrote about autorun eater in ur first post, and now u say "This software not only stop virus but delete it."
Simply use Kaspersky yaar, its best and monitors all these stuff efficiently better than any other software...My system never got infected since i m using it for 10 months...!!
My Rig:
GFX Card : ???
HTC Touch Pro
di9it is offline
Best anti-virus solution for combating LAN viruses cpkumar Software Q&A 1 23-07-2006 11:55 AM
needs solution to work DVDs on cd drive ? shreyadr QnA (read only) 7 01-04-2005 06:11 PM
Solution for Samsung CD-RW Drive tray problem sms_solver QnA (read only) 8 25-03-2005 10:39 PM
- by gohan89
