Old 21-02-2009, 07:09 AM   #1 (permalink)
rajwansh2003's Avatar
Default Utorrent too slow!!!!
My utorrent is downloading at speed approx 10 to 15kbps but when i am downloading using mozilla firefox it download with 60-90 kbps. please help me to increase the speed of utorrent ?
Anupam
rajwansh2003 is offline
Old 21-02-2009, 10:04 AM   #2 (permalink)
Back!
red_devil's Avatar
Default Re: Utorrent too slow!!!!
were there enough seeds for the file that you were trying to download ??
red_devil is offline
Old 21-02-2009, 12:42 PM   #3 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Yup, the download speed entirely depends on the seeds and peers, it's not like normal downloads.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 21-02-2009, 02:07 PM   #4 (permalink)
silentFOX
mittyr's Avatar
@rajwansh2003
Did U try tweaking the settings in utorrent ?? ( A quick google). To add, ter's no ideal setting, varies from your "download rate" & that particular torrent.
Get "indian" torrents as early as possible to get good speeds. I get 150-200kbps avg, look around for good sources
mittyr is offline
Old 22-02-2009, 12:03 AM   #5 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
^^I'd actually recommend the other way round. Get foreign torrents. Indians are lazy and dont seed much in their limited accounts. Foreigners have better connections and better unlimited internet.
dheeraj_kumar is offline
Old 22-02-2009, 02:29 AM   #6 (permalink)
silentFOX
mittyr's Avatar
@dheeraj_kumar
Get "indian" torrents as early as possible to get good speeds. I get..
Thou i meant d same thing U said, guess i didnt make it clear
mittyr is offline
Old 22-02-2009, 04:17 PM   #7 (permalink)
dude, if the torrent is slow add more trackers to it.
manoj_mafiosi is offline
Old 24-02-2009, 09:08 PM   #8 (permalink)
I have 2.4 Mbps BSNL EVDO. and the problem is i have static IP address. can any one tell or give link to by-pass u-torrent.
Anupam
Old 25-02-2009, 10:36 AM   #9 (permalink)
fabler's Avatar
Following link might help you..
http://www.chip.in/forums/viewtopic....orrent#p346164
fabler is offline
How can i fix this in utorrent? Cool Joe QnA (read only) 5 10-07-2008 07:28 PM
Help me use utorrent ajaybc Software Q&A 6 19-07-2007 07:44 PM
Utorrent wizrulz QnA (read only) 2 20-12-2006 10:16 PM
What is this in utorrent ? manas QnA (read only) 2 26-11-2006 12:12 PM
UTorrent so slow findsofts Software Q&A 7 04-09-2006 03:20 PM
- by gohan89
