Old 16-02-2009, 04:08 PM   #1 (permalink)
PC Addicted
Default Help with net connection..
I just got Internet connection at my home but I can't login using software.
I have to open browser window and have to keep it minimised.
Here is image.
http://lh6.ggpht.com/_AtVeUixS-x0/SZ...lipboard01.jpg
What should I do?
Also can anybody tell me how to use oDC?
Playing hack-n-slash games using keyboard+mouse is injurious to both of them.
G33K n G4M3R is offline
Old 19-02-2009, 11:25 PM   #2 (permalink)
aswin1's Avatar
Default Re: Help with net connection..
Call your ISP and ask them to fix it. Alternately download the latest version of 24ONLINE from their website and install it. Try logging in.
aswin1 is offline
Old 27-02-2009, 09:03 PM   #3 (permalink)
PC Addicted
I have latest version 24ONLine.
& downloaded linux version too.
Have to try hard to install.
Old 27-02-2009, 10:40 PM   #4 (permalink)
Pratul_09's Avatar
24Online is crap they buy in bulk from Sify Broadband and then sell it to sify BB customers. Find any Other ISP in your area, otherwise go for Cablenet if available.
Pratul_09 is offline
Old 27-02-2009, 11:00 PM   #5 (permalink)
PC Addicted
I don't have Sify, iam cablenet user(Honesty).
Is sharing of internet connection on 3 OS is a problem?
Old 28-02-2009, 08:40 AM   #6 (permalink)
Pratul_09's Avatar
You can use some proxy software like CCPROXY to share the connection between 1 or more computers. By default only 3(Paid version will allow more). Then see if you face the same problem.
Also check that QOS bandwith is set to zero in settings. This will boost approx 20% of internet speed in each machine you share internet. Sharing of internet in same machine on more OS is not a problem at all. Non windows have almost same settings but differently.
Old 04-03-2009, 10:45 PM   #7 (permalink)
PC Addicted
Now I downloaded tarball and extracted it.It contained a readme(which contains nothing about installation or how to run it) and executable.
I copied executable to my bin directory(not in /bin) and started terminal,as double clicking that file didn't worked and
typed following
$ crclient -u pratham1989
and all I got was this:
./crclient: You can run the executable with name `crclient' only.
Please tell me what to do and if possible how to install client again.
I tried this method reading here:
http://www.linuxforums.org/forum/red...am-client.html
Which connection to take? GeekyBoy Mobiles and Tablets 7 03-10-2008 01:30 PM
help me with the connection shift Chit-Chat 6 08-04-2008 09:12 PM
Want a basic mobile and connection for net connection Chetan1991 Mobiles and Tablets 5 31-10-2007 11:13 AM
Need help with DSL connection thadeus Software Q&A 8 12-08-2006 06:49 PM
USB connection for HDD godsownman Peripherals 5 04-07-2005 04:01 PM
- by gohan89
