Originally Posted by toqeer
i installed vista then xp in my pc but afer installing xp vista not works why?
why we cant installed xp after vista.
when i installed xp first then vista then both works right why?
I think you got messed with bootloader of Windows XP. Tell me if you are facing the following scenario in your PC.
You installed Windows Vista and it was running just fine. Then you took out Windows XP CD and installed it on other partition/HDD. Now, hell broke loose, suddenly Windows Vista is not showing up in the bootloader and the PC is automatically going to Windows XP.
