Hi all,
My PC config is AMD X2 5600+ and Asus M2M68 mobo with onboard nForce 7 gfx.
Last night I installed the drivers that came with Digit DVD this month. It asked me to uninstall previous drivers and it automatically did so...but the next time I rebooted, my display has gone all blank. After the boot screen, nothing comes. Just the black screen. I can't boot into Safe mode as it gets restarted. And If i select 'Enable VGA mode'(F8 advanced options), my mouse and keyboard don't work.
The other problem is with the motherboard CD drivers. I installed
XP Home edition with SP1. Then I installed the drivers from the MOBO CD. But even though my gfx is detected correctly, the display resoultion is 800x600 at 4-bit color. Later I found there are no drivers installed for 'Plug and Play' monitor. (Mine is LG StudioWorks ). 700E). If I uninstall the display drivers, I can select higher resolutions at 32-bit color but then the onboard gfx is not detected. Do I have to install SP2 for XP?
I am in a dilemma. Please help. I love my computer more than the 'pink' day.
