Old 12-02-2009, 11:33 PM   #1 (permalink)
Exclamation Dvd Video Problem.....
I have a Dual Layer DVD of the movie DDLJ.When I insert the DVD into my drive and manually open the VIDEO_TS folder and open any .VOB file then the video displayed is blurred as if the DVD has many scratches but if I re-insert the DVD and in the autoplay menu select "Play DVD Movie" option then everything works fine and the video quality is at its best.
The DVD also has two other folders named AUDIO_TS(empty folder) and JACKET_P(contains three .MP2 files).These flders are found in all DVD movie DVDs.What are they for??? and waht is the use of the .BUP and .IFO files in the VIDEO_TS folder ( for example: VTS_01_0.BUP and VTS_01_0.IFO )
harpreet115 is offline
Old 12-02-2009, 11:59 PM   #2 (permalink)
Wise Old Mouse
mrintech's Avatar
Default Re: Dvd Video Problem.....
Use: http://www.videolan.org/vlc/
mrintech is offline
Old 13-02-2009, 12:18 AM   #3 (permalink)
I have tried VLC Media Player, KM Player, Nero Show Time but none have worked so far...
Old 13-02-2009, 12:34 AM   #4 (permalink)
damnbadman666
damngoodman999's Avatar
Dont use bold letter plzz
damngoodman999 is offline
Old 13-02-2009, 12:48 AM   #5 (permalink)
Wise Old Mouse
mrintech's Avatar
Maybe the DVD's you are using are corrupt
mrintech is offline
Can I make Video DVD of 70 different Video Files ? satyamy Software Q&A 3 30-06-2008 09:44 PM
How to convert a video dvd into video cds without reducing quality arunks Software Q&A 4 21-09-2007 08:05 PM
Video rendering problem!-in ULEAD VIDEO STUDIO nithinks QnA (read only) 1 02-08-2005 06:52 PM
- by gohan89
