Old 11-02-2009, 10:46 PM   #1 (permalink)
mortal kombat
quan chi's Avatar
Default urgent help required.
hi friends.
well today after inserting a pen drive to the system.
1. i double clicked on it but nothing happened so i had to open it by rightclick>open.
then i copy pasted some datas to it.then i removed the pen drive by simply pulling it out.
2.then i turned off the system.now when i started it i cannot acces my two ( C: and E: ) drives by double on clicking them.i get this message.
so i have to open it by rightclick>open.
how to make it again open by double clicking
please help.
quan chi is offline
Old 11-02-2009, 11:22 PM   #2 (permalink)
Default Re: urgent help required.
just open drive go to tools>folder options
then go to view tab just select Show hidden files option then click apply and ok then in drive u will see autorun.inf file just delete also scan ur computer with an antivirus like quickheal or norton or avira or any other to remove the infection of virus. also use spybot to scan
abhijangda is offline
Old 11-02-2009, 11:49 PM   #3 (permalink)
Wise Old Mouse
mrintech's Avatar
http://www.superantispyware.com/download.html
mrintech is offline
Old 12-02-2009, 09:57 AM   #4 (permalink)
Pragadheesh's Avatar
its a damn old virus buddy..!! a proper virus scan with kaspersky or something would help you out..
Pragadheesh is offline
Old 12-02-2009, 12:56 PM   #5 (permalink)
D'load COMBOFIX and RUN it. Before that disable system restore
mkn4372 is offline
Old 12-02-2009, 01:27 PM   #6 (permalink)
its a virus!!!!
hell_storm2006 is offline
Old 12-02-2009, 07:58 PM   #7 (permalink)
its a kind of Trojan virus
scan your computer with a good anti-virus,like kaspersky, norton etc
daudkhan is offline
Old 13-02-2009, 04:42 PM   #8 (permalink)
Gamer Forever!
in explorer go to tools -> folder options -> show hidden files
open each drive using right-click -> open. u'll see a file called autorun.inf in each of the drives. delete that file.
Using a 17" MacBook Pro
Running Mac OS X Lion and Windows 7 Ultimate
Hardware: Core i5 M540 @2.53GHz; Nvidia GeForce GT 330M 512MB; 8GB RAM; 500GB HDD
thestrategist is offline
Urgent help required Hari_04415 Software Q&A 4 16-08-2007 11:29 AM
urgent help required.......... kuldeep bhardwaj QnA (read only) 1 10-11-2006 03:25 PM
urgent help required rahulshah19 Hardware Q&A 1 29-06-2006 05:46 PM
Urgent.. New MB required dilip281 QnA (read only) 3 24-10-2005 11:39 PM
urgent help required harshagarwal QnA (read only) 2 17-09-2004 01:25 AM
