Old 11-02-2009, 06:27 PM   #1 (permalink)
shyamno's Avatar
Default Problem With Windows XP Pro
I am having a weired problem with my set up.My USB to serial cable,webcam ..or rather all USB products except pendrives are not being detected.Some products like webcam gets detected but the driver gives problem.
I have formatted the system with various XP setups.During this only once ... all went right.But again when i formatted the system the same old story.
Why it is so ??
BTW all the XP setups which i tried were SP2 and i m working on laptop.Plz help me.I m doing my project on my laptop and it needs all those USB to serial converter and Webcams working proeprly.
Visit my Blog::::::
http://shyamkol.blogspot.com
shyamno is offline
Old 22-02-2009, 12:10 AM   #2 (permalink)
Default Re: Problem With Windows XP Pro
are you sure all your USB devices have enough power to be working together? USB devices draw power from the port itself... however in this scenario, if you plug in your devices one at a time... alone... it should work... if the device is not detected even if it is the only USB device connected... then it is something else...
6laz3r is offline
Linux AV problem or windows AV problem?? thilina Open Source 2 02-09-2006 09:27 PM
Windows Xp problem... readermaniax Software Q&A 8 19-08-2005 10:31 AM
windows serious problem KoRn Software Q&A 1 01-07-2005 09:48 PM
windows 2000 and windows 98 problem swap_101982 Software Q&A 4 30-04-2005 12:04 AM
