Old 04-02-2009, 05:21 PM   #1 (permalink)
I'll xploit ur Territory
niraj trehan's Avatar
Default UNKNOWN BURN PHASE vid NERO???
earlier i used to get the following during burning dvd's
"burn process started succesfully at 20x"
but it comes
"unknown burn phase"
<<XFX 680i TLi chipset>>Dual core 2.8Ghz>>2*1GbTranscend 800 hz>>8800 GTX XXX 768 Mb..GTX 260 862 Mb now GTX 280 1 Gb>>Cabbi CM 690 Nvidia SLI>>CM OEM 600w>>APC 1Kva UPS>>
niraj trehan is offline
Old 04-02-2009, 06:05 PM   #2 (permalink)
silentFOX
mittyr's Avatar
Default Re: UNKNOWN BURN PHASE vid NERO???
> Have U tried any other burning program - Imgburn (its free) or upgrade to the latest version of Nero.
> May be a firmware upgrade will do if ter's still problem.
> Suggest lowering the "Burning Speed" & try a different disc-brand
mittyr is offline
Can Nero Burn .mkv format video to DVD? boom2709 Software Q&A 14 19-08-2008 08:37 PM
Nero Iso Burn jamifahad Software Q&A 4 06-01-2008 03:43 PM
Nero Unknown BurnPhase jack_the_ripper Software Q&A 10 27-12-2007 11:47 PM
how to burn ONLY mp3 cd in nero 7.9.6.0 ? pro Software Q&A 5 01-07-2007 02:01 PM
Burn a 800MB (90min) cd using Nero sailendra Software Q&A 28 13-01-2005 06:34 PM
- by gohan89
