Old 27-01-2009, 01:43 PM   #1 (permalink)
Angry Winzip Extracting Problem
hi eveybody.
i'm a newbie here.plz help me to extract a zip file that says
"Error: unable to create output file "H:\Softwares\??????????.bin".
i think the name of the file is in arabic/chinese.how can i extract this ???
Plz help me. thanks to u all
tweaker is offline
Old 27-01-2009, 04:37 PM   #2 (permalink)
Rapacious eBayer
Default Re: Winzip Extracting Problem
H:?? Check if you're extracting the file to a hard drive.
Try renaming the file from within the Winrar explorer interface before extracting it.
•Favorite track Of '07: Dash Berlin - Till The Sky Falls Down
•Favorite track Of '08: Emilio Fernandez - Reynosa
•Current favorite track: Blackfeel Wite - On The Down (J-Soul Vocal Mix)
gforce23 is offline
Old 27-01-2009, 06:19 PM   #3 (permalink)
silentFOX
mittyr's Avatar
The files extensions are *.bin & *.cue ?? Is it a movie??
If so, U need to mount with Daemon Tools or anything of that like
OR
use VLC Player it can directly play it.
OR
Burn directly to CD using NERO & play it on your DVD Player...it will read
mittyr is offline
Old 27-01-2009, 06:48 PM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Winrar has a rename option in its right click menu. Try renaming it. Also, make sure your entire path does not exceed 256 (or 64??) characters.
dheeraj_kumar is offline
Old 28-01-2009, 05:42 PM   #5 (permalink)
Talking Re: Winzip Extracting Problem
it works thanks for ur replys.
winrar extrats that file succesfully even without renaming.once again thanks
tweaker is offline
Problem with extracting files..CRC checksum error akshaykapoor_3 QnA (read only) 2 23-03-2008 10:18 PM
Winzip Self-Extractor problem ComputerUser Software Q&A 3 16-06-2007 02:13 PM
WinZip 11.0 is out! sabret00the Technology News 1 19-11-2006 11:05 AM
WinZip 10.0! Now Available! naveenchandran Technology News 12 01-12-2005 09:26 PM
problem extracting image files stone cold QnA (read only) 12 25-10-2004 07:31 AM
- by gohan89
