Old 27-01-2009, 12:11 AM   #1 (permalink)
Question Master sound output control
I use headphones a lot rather than external speakers. Sometimes the audio of some video/music/game.. is very high or very low, and every time I've to open the volume control or adjust it in the program itself. Is there any software which limits the audio output to some decibels no matter what is playing underneath, its ok if I've no control over the lower limit, but I should be able to control the upper limit.
RandomNumber is offline
Old 27-01-2009, 06:46 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: Master sound output control
AC3 Filter. Install K-Lite Mega Codec Pack, and use the provided AC3Filter to do the job. The program is pretty self-explanatory.
You can also get it from www.ac3filter.net
dheeraj_kumar is offline
No sound output <Strange> gearShifts Hardware Q&A 14 01-02-2007 10:29 PM
Diff in Sound Output.. nitish_mythology Open Source 6 14-05-2006 09:20 PM
Problem in DVD sound output udhaybhavan QnA (read only) 4 06-01-2005 11:07 AM
how to master the Off-the-ball control Knight QnA (read only) 2 02-09-2004 09:36 PM
- by gohan89
