Originally Posted by niraj trehan
so does that mean that delete file is gud option??
and this cums in the avast4.8 home edition (i have ths one only) also.
i think open source any antivirus has this option apart from the ones vich r purchased.
Almost every antivirus has option of deleting the infected file it coudn't repair.
It is a good option or not?? well, that's your choice. If the file is a system file or of very importance to you, you should quarantine it and let it be moved into chest where no virus can access it and application will be able to interact with it, until you move it out of the chest. You can try repairing the file later on, after you've updated the virus database of the antivirus. If the file isn't very important , you should just delete it. Oh, and I've personally found avast as a great antivirus. It catches viruses very efficiently. I don't know any other free antivirus which is as good as it is.
