Old 14-01-2009, 01:52 PM   #1 (permalink)
Default data execution prevention
what is data execution prevention?
whenever i'm connecting to internet, "Data execution prevention for generic host process 32"this dialog box is coming and if i close it, net is not working. even no data tranfer is taking place. i have to restart my system.
is this data execution prevention of any help? or i can manually configure to close it. if it can be closed, tell me the procedure to do so
snehangshu is offline
Old 19-01-2009, 10:08 PM   #2 (permalink)
Default Re: data execution prevention
DEP is good for security... generic host process generally means svchost.exe... thats the container under which several services run including the all important RPC... if DEP is stopping you, then it most probably means that there is something suspicious trying to run as a service... do a scan and check... also check in services.msc and see if you find something odd
yes, you can disable DEP... follow this link...
http://blogs.technet.com/askperf/arc...ot-to-dep.aspx
6laz3r is offline
Data Execution Prevention (DEP) Exception channabasanna Software Q&A 4 20-10-2008 10:20 AM
data prevention error....whas that?? ajooba215 Software Q&A 1 26-08-2008 07:47 AM
How To Disable Data Execution Prevention aka DEP topgear Tutorials 5 09-04-2008 07:09 PM
Data Execution Prevention ashu_dps Software Q&A 8 21-08-2006 09:10 PM
mysql attack, prevention sunnydiv Tutorials 4 12-03-2005 11:47 AM
- by gohan89
