Old 08-01-2009, 07:35 PM   #1 (permalink)
aneek's Avatar
Unhappy Auto Play Problem In Vista
Hi guys,
I have Vista Running in my computer for long. But today I was encountered a strange problem.
My DVDs in not autoplaying.When I insert a mixed DVD in to my DVD Drive The "DVD RW Drive" shows only the size of the total DVD and free space.When I double click on that it promots "Prepair the blank Disk"to format the disc and gives me the default write option as Vista provides. If I open or explore then also the write option pops out. I've enabled the autoplay options in many ways i.e, "Ask me every time" and also as "Open folder to view files using Windows Explorer".
But if I restart my machine with the DVD inside on the drive then after restart when the computer starts, if I go to the computer and on double click on the DVD RW Drive icon then the DVD opens...And functions perfectly.....
Please help me on this because how many times I restart to get a DVD to run..??? Its very annoying.So please post a solutions.....
I'm Providing some Pictures....Please See them and Help me on this Problem...
aneek is offline
Old 09-01-2009, 07:22 AM   #2 (permalink)
aneek's Avatar
Unhappy Re: Auto Play Problem In Vista
Tried To solve the problem But..................
Hi,guys..........I'm doing some things to my computer to enable autorun but, no success yet....
1.I Ensured that Shell Hardware Detection service is running.
2.I navigated to
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servic es\CDRom
to see whether
the AutoRun registry value in the right pane was zero or not. Yes it was and I changed it to 1.
There also I saw that a key named AutoRunAlways Disable of REG_MULTI_SZ type has the value data of TORiSAN CD-ROM CDR_C36
NEC MBR-7
NEC MBR-7.4
PIONEER CHANGR DRM-1804X
PIONEER CD-ROM DRM-6324X
PIONEER CD-ROM DRM-624X.
I don’t know what to do with it..
3.Again I navigated to HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Policies\Explorer to see the the NoDriveTypeAutoRun registry entry on the right pane. To enable AutoPlay on all drive types, I set the NoDriveTypeAutoRun to 0 (zero).
4. Also I've twicked on
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\Explorer
NoDriveTypeAutoRun = 0x00000095
-and-
HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\Cur rentVersion\Policies\Explorer
These are all correct measures taken I know. But Tell me about the
NEC MBR-7
NEC MBR-7.4
Thing.........What to do with it..??????????????????????????????????????? Help Please.....
aneek is offline
Keeping Vista Auto Updates while reformating. shan111 Software Q&A 1 10-09-2008 07:02 PM
how to disable vista auto sorting files ranjan2001 Software Q&A 1 15-04-2008 12:53 PM
auto play guruten Hardware Q&A 3 29-09-2007 11:45 PM
How to Auto-Login in Windows Vista Beta 2 PrinceHeart Tutorials 2 20-07-2006 01:16 AM
- by gohan89
