Old 06-01-2009, 01:57 PM   #1 (permalink)
Lets Do It!
amrawtanshx's Avatar
Default Problem burning DVD's using Nero.
Wasted 6 DVD's today.
The writer was fine 3-4 days back.Now I get this error.
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Old 07-01-2009, 09:13 AM   #2 (permalink)
It doesn't matter!
Sumeet_naik's Avatar
Default Re: Problem burning DVD's using Nero.
Could be background process.. Try burning after restarting.. If its a pc, then try the drive on another pc..
Twitter - http://twitter.com/Sumeet
Blog - http://sumeetnaik.blogspot.com
Lenovo Y410 775787Q + SE K530i
Sumeet_naik is offline
Old 07-01-2009, 10:35 AM   #3 (permalink)
channabasanna's Avatar
Try by burning the disc in lower speeds, When i used to burn DVD's at 8x speed or sometimes in 6x, i used to get the same error. The burning would fail. But after i started burning the discs at 4x speed, i never got any Error.
C2Q Q6600 G0|ASUS Maximus Formula|XMS2 1GB x2|CM extreme Power 600W|CM Elite 332|WD 320GB HDD|Seagate 80GB HDD|SONY DVD+RW|Viewsonic VA1912wb 19"|XFX 7600GS|OCZ Vendetta 2|HP dv2601tx|Nokia N73 ME
channabasanna is offline
Old 07-01-2009, 07:30 PM   #4 (permalink)
TheSaint
NucleusKore's Avatar
What you do is disable you anti virus, anti spyware, antishitwhatever, turn off your internet connection, and then try burning at 4x
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 07-01-2009, 09:07 PM   #5 (permalink)
oh lol...you have utorrent on and kmplayer too. Did you expect a clean error free burn then
Faun is online now
Old 08-01-2009, 07:48 AM   #6 (permalink)
Lets Do It!
I dont have any antivirus installed as I solely trust Windows Defender
And why turn off internet connection ?
Do uTorrent and KMPlayer really interfere in burning DVD's ... How ? :S
I always burn @ 4X or 6X never more than that.
Old 08-01-2009, 04:14 PM   #7 (permalink)
Beta Waves's Avatar
It could be due to KM Player, especially if you are playing video...
I am Back....
Beta Waves is offline
Old 24-01-2009, 03:40 PM   #8 (permalink)
i have a Dvd burn problem its take 45min each one dvd & cd.
sureshpaladi is offline
Old 25-01-2009, 12:18 AM   #9 (permalink)
silentFOX
mittyr's Avatar
As said, better to leave the burning al alone. Try a diff burning appn to make sure its not Nero.
@sureshpaladi
PC Specs?? OS??
Try this it shud solve it
My Computer > Hardware > Device Manager > "Click/Expand" IDE ATA/ATAPI Controllers.
Then "Select" Primary IDE Channel > "Right Click" Properties > Advanced Settings > Transfer Mode "If its "PIO Only" change it to "DMA if available". Do the same for "Secondary" if its there.
If your not able to select or switch to "DMA Mode", "Right Click" on Primary IDE Channel and "Uninstall" it. Dont worry Windows will recognize it in next boot-up
mittyr is offline
Old 25-01-2009, 01:11 AM   #10 (permalink)
<Sparkling Pwnies>
Anorion's Avatar
Also use good quality branded disks
Anorion is offline
Old 25-01-2009, 04:30 AM   #11 (permalink)
Freak Beta 1
Dark Core's Avatar
Try using other softwares such as CD Burner XP or Ashampoo Burning Studio or anything else.,
If it doesn't work Right Click on Computer | Manage | Device Manager, Choose your DVD Writer and Uninstall and restart the PC windows will reinstall the drivers the next time you switch on the PC.
@Others
Actually what is the use of writing at low speeds, I always prefer to write at maxium speed. Will there be data loss or something when we write at max speed???
Twitter : www.twitter.com/arunselvakumar :twisted:
Facebook : www.facebook.com/arunselvakumar :evil:
Dark Core is offline
Old 25-01-2009, 05:00 AM   #12 (permalink)
<Sparkling Pwnies>
Anorion's Avatar
^ Failure in writing is just more probable on faster speeds
Anorion is offline
Old 25-01-2009, 05:35 AM   #13 (permalink)
Freak Beta 1
Dark Core's Avatar
@Anorion
Means we need to burn at low speed when we experience failures right ? Do you recommend to write at lower speed all time? I hate to wait for long time when writing DVD's
Old 25-01-2009, 11:48 AM   #14 (permalink)
a.k.a VipER
Ecstasy's Avatar
It's always said that you should close all the application while burning a CD/DVD as it might interfere with the burning process.
Originally Posted by shayanthebest View Post
I want to buy a new computer which can play 2-3 year old games at good resolutions. My budget is 5 to 6 lakhs. Please help
Ecstasy is offline
Old 25-01-2009, 02:58 PM   #15 (permalink)
<Sparkling Pwnies>
Anorion's Avatar
yes, burning at slower speeds all the time is a good idea.
Anorion is offline
Old 25-01-2009, 05:56 PM   #16 (permalink)
silentFOX
mittyr's Avatar
@Black Core
If its "Data DVD", yes i wud suggest "slow speed" as they can/may become un-usable when trying to write the compressed data too quickly. U shudn't be worried much about "Video DVD" though.
Does it take more than 10mins to write a DVD@4.38GB ?? If u still want to stick to high-speed, use "DVD+R" as they are more stable
mittyr is offline
Sony Dvd-writer churning out blank dvd's after burning......pls help tango_cash Hardware Q&A 10 08-10-2008 05:51 AM
Having problem burning DVD's using my Liteon DVD Writer! ajayritik Hardware Q&A 5 17-07-2008 07:30 AM
session problem in burning DVD's ritish Software Q&A 5 21-02-2008 02:10 AM
Difference between burning CD/DVD as MP3 Vs burning as DATA CD/DVD in Nero ajayritik Software Q&A 1 06-09-2007 07:33 PM
Serious burning problem with Nero 7, Help needed!!!!!!!! Andyiz Software Q&A 2 19-01-2006 03:05 PM
- by gohan89
