Old 02-01-2009, 01:15 PM   #1 (permalink)
Default Help me please
How can i remove the "Windows Script Host" it says Loading Script C:\WINDOWS\auto.vbs (Access is denied ) . please help me....
jix33 is offline
Old 02-01-2009, 01:29 PM   #2 (permalink)
Wise Old Mouse
mrintech's Avatar
Default Re: Help me please
How to remove this "Windows Script Host" Error? - Please Help
- MrinTech :)
mrintech is offline
Old 02-01-2009, 01:49 PM   #3 (permalink)
It's still the SAME (
jix33 is offline
Old 02-01-2009, 02:10 PM   #4 (permalink)
Wise Old Mouse
mrintech's Avatar
1. From the start menu click Run -> type Regedit
2. Registry Editor will open
3. In the Registry Editor, go to Edit menu and press find
4. In the find dialog box type - auto.vbs and press find next button. Delete this auto.vbs entry
5. Press F3 (find next) to see if the same path exists somewhere else in your registry. If found again at some other place remove the path there also.
6. Repeat F3 until you get a message that search has finished.
- MrinTech :)
mrintech is offline
Old 02-01-2009, 02:38 PM   #5 (permalink)
What about SSCVIHOST.exe error? i have that too
jix33 is offline
