Old 31-12-2008, 11:24 PM   #1 (permalink)
Default Not able to open any drive? please help-Virus
I just formatted my system and find problems like this...Whenever i open any other drive except C: drive i get error saying "resycled\boot.com is not valid win32 application"...What should i do now?...I have put avast and zonealarm firewall they dont dtect anythin and also
Whenever i start the computer i get the language bar at the buttom in the taskbar how do i disable tat..I have to roghtclick everytime at the taskbar to disable it..Is der anyway to totally disable it
Waiting for replies
roonie is offline
Old 31-12-2008, 11:30 PM   #2 (permalink)
Wise Old Mouse
mrintech's Avatar
Default Re: Not able to open any drive? please help-Virus
It's a Trojan. Immediately scan with: http://www.superantispyware.com/download.html & http://www.emsisoft.com/en/software/free/
Also completely update the definition database software and RUN full scan on all drives
Problem will be Solved
- MrinTech :)
mrintech is offline
Old 01-01-2009, 01:30 AM   #3 (permalink)
No its still der...I have updated both of your given softwares and ran a full system scan..Anything else to try
roonie is offline
Old 01-01-2009, 10:35 AM   #4 (permalink)
Wise Old Mouse
mrintech's Avatar
Open a cmd prompt. Start > Run... [type in] cmd > Ok
At the prompt, enter the following commands:
attrib -h -r -s C:\Autorun.inf
del C:\Autorun.inf
attrib -h -r -s D:\Autorun.inf
del D:\Autorun.inf
etc.
(do this for every drive letter (C: D: E: etc) and do NOT open any drives with
Explorer until you're completed)
Another Method
You should do these steps after a fresh reboot or in safe mode.
1) Navigate to the problem drive(s) via the Explore option.
2) Click on TOOLS -> FOLDER OPTIONS
3) Click the button which says ‘Show hidden files and folders.
4) UNCHECK the following boxes:
Hide extensions for known file types
Hide protected operrating system files
5) Find and delete the autorun.ini file and the resycled folder on the root directory of all affected drives.
6) Check “c:\windows\system32\dllcache” for boot.com file and delete it if present.
7) Check “c:\windows\prefetch” for boot.com file and delete if present.
8) Delete all files from c:\windows\temp
(Some files may not delete, that’s ok, they’re in use by the system and not virus files.)
9) Delete all files from c:\Documents and Settings\[USER PROFILE]\Local Settings\Temp
(Again, a couple files may not delete, don’t worry.)
10) Run Regedit
11) Make sure you are at the very first entry of the registry hive. (y Computer should be hilighted) then click EDIT -> FIND
12) Search for “boot.com”. If it finds an entry, delete it. Keep hitting F3 until you’ve deleted all instances of boot.com in the entire registry.
13) Scroll the left comumn back up to the top and hilight the My Computer again at the top of the registry hive.
14) Click Edit -> Find again and search for ‘resycled’ and repeat as in step 13, deleting the entries as it finds them. (I found 2 of each)
15) Close registry editor and try opening the infected drives. They should work now.
- MrinTech :)
mrintech is offline
Old 01-01-2009, 11:34 AM   #5 (permalink)
Great working now...Thanks a lot...Dint expect this...
Cool work-Again thanks a lot for helping
roonie is offline
Old 01-01-2009, 12:01 PM   #6 (permalink)
Wise Old Mouse
mrintech's Avatar
- MrinTech :)
mrintech is offline
Old 21-01-2009, 08:28 AM   #7 (permalink)
When I want to open any drive, a pop-up massage shown up every time like this.
The C:\application cannot be run in win32 mode.
ok
But I am able to open only the my Documents. What is tthe problem? Can I apply the above tweak to my PC?
suniltr77 is offline
Old 21-01-2009, 10:37 AM   #8 (permalink)
Wise Old Mouse
mrintech's Avatar
Follow this method
del C:\Autorun.inf
del D:\Autorun.inf
etc.
Also go for full scan with updated definition with the following:
* http://www.superantispyware.com/download.html
* http://www.emsisoft.com/en/software/free/
Do reply back about the Results
- MrinTech :)
mrintech is offline
Old 22-01-2009, 07:46 AM   #9 (permalink)
During the process the DOS prompt flashes for a split of second and disappears. I thought it might went wrong. But after deleting the .ini files and a reboot the problem is over. Thanks a lot.
cant open my d drive plz help avtarkaint Software Q&A 5 10-05-2008 12:59 PM
problem to open drive(ex. c:) patelviren QnA (read only) 3 13-11-2007 11:02 AM
Plz help... UNKNOWN VIRUS (open outlook) almighty Software Q&A 9 30-09-2007 01:09 PM
help me.. virus... not able to open mozilla the.kaushik Software Q&A 12 30-08-2007 04:27 PM
Drive does not open....help plz sanphoe Software Q&A 6 24-04-2007 03:11 AM
