Old 31-12-2008, 03:54 PM   #1 (permalink)
Unhappy Having issues with my broadband
Hi, today I got my airtel broadband connection. 799 plan 256 kbps unlimited. Now the sites do open and all and most Indian sites work fast but whenever I try to download anything or access international sites like wikipedia the net is dead slow.On airtel broadband speed test it shows my speed is 260 kbps+ but on speedtest.net it shows <60 kbps.
Am at a failure to understand whats going on because I did tons of research before choosing airtel and had heard all praises for it.However I have also heard that due to some issues with the data lines connecting India breaking down all broadbands will have lower speeds for a while.Is anyone else facing the same problems like me???.
Or could it be because its just been 3 hours since I got my connection and the guys at airtel told that it takes atleast 24 hours for the activation report to reach the servers.
Anyone got any clue why am facing this problem??.Spyware?? Malware?? HELP??
rock_on is offline
Old 31-12-2008, 04:03 PM   #2 (permalink)
Wise Old Mouse
mrintech's Avatar
Default Re: Anyone else having issues with their broadband????
As per some NEWS sources complete affect due to cable cut wil be rectified by today and all Internet connection will be restored from tomorrow or on 2nd of Jan. Some sites are slow. But as a precaution have a scan with: http://www.superantispyware.com/download.html
Also I am on Airtel Too, but don't have problems now. Go for scan and wait for atleast 2 days. Otherwise call the Airtel CC
- MrinTech :)
mrintech is offline
Old 31-12-2008, 04:07 PM   #3 (permalink)
Give more descriptive title next time.
I haven't heard any Airtel BB user complaining about service. What speed are you getting while downloading any fiile? Wait for some time, the problem must be rectified .
As you have got unlimited always on internet connection, it's must to install antivirus and antispyware software and keep them updated. Also install a firewall.
ThinkFree is offline
Old 31-12-2008, 04:24 PM   #4 (permalink)
AFK
thewisecrab's Avatar
Must be due to the cable cut in Europe. I heard that the prob will be rectified by the end of the week.
Even so, do scan your PC with updated signatures of your AV and anti-spyware software just to be sure.
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Old 31-12-2008, 04:28 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
Call airtel customer care ask regarding your problem.
ravi_9793 is offline
Old 31-12-2008, 04:57 PM   #6 (permalink)
I get around 3 kbps while downloading from sites like gametrailers
rock_on is offline
Old 31-12-2008, 05:46 PM   #7 (permalink)
The Researcher
Even with my BSNL Home 500 plan my download speed has decreased by 50%. As you say indian sites are opening properly means it is not the problem with airtel but rather due to undersea cable cut. I don't know when they are going to rectify it.
Ramakrishnan is offline
Old 31-12-2008, 07:43 PM   #8 (permalink)
Problem solved .Once I heard that am the only one getting probs with airtel i got pissed and ran multiple spyware and antivirus checks.And then deleted all software which could check for auto updates.Now my net is running like butter.Omfg airtel rocks way better than the shitty mtnl I had before
rock_on is offline
Old 31-12-2008, 07:46 PM   #9 (permalink)
Congrats
Wish you happy browsing on Airtel and happy new year.
Old 02-01-2009, 09:11 PM   #10 (permalink)
its my speed with airtel 799...is it alrite????
ashishstillthere is offline
Old 03-01-2009, 02:16 PM   #11 (permalink)
Location?Speed is great if it's 256kbps u/l plan, but ping isn't.
Old 05-01-2009, 09:34 AM   #12 (permalink)
i am from delhi
here is another
how is this???
but i wana know why i am alwaz getting speed of 28-32 kbps and this site is showing my speed of 384
Old 05-01-2009, 12:54 PM   #13 (permalink)
DMs show speed in kilo Bytes per second(kBps) while speedtest(by default) uses kilo bits per second(kbps). That's why that speed while downloading.
1kBps=8kbps
So 32kBps=256kbps which is what you should get on that plan.
Old 05-01-2009, 04:12 PM   #14 (permalink)
a.k.a VipER
Ecstasy's Avatar
I got MTNL, even I'm getting slow speed while downloading but while surfing its very good. I'm getting speed of 7-8kbps while downloading atm.
Originally Posted by shayanthebest View Post
I want to buy a new computer which can play 2-3 year old games at good resolutions. My budget is 5 to 6 lakhs. Please help
Ecstasy is offline
Old 08-01-2009, 11:55 PM   #15 (permalink)
what is this ping thing??
Old 09-01-2009, 12:29 AM   #16 (permalink)
Ping is the time it takes for a round the world journey by any packed send to make that trip..lolz
Faun is offline
Old 09-01-2009, 09:16 AM   #17 (permalink)
then how its value differ???n vat will be its use???i mean how my speed is gud bt ping is not
Old 12-01-2009, 09:35 AM   #18 (permalink)
Designer Here
techking_dinesh's Avatar
according to TRAI u get dload speed of ur plan speed divided by 8
see my results
i m very satisfied
as u can c
i selected mumbai as server to test and nt lahore
and i m getting this speed in INDIA only
techking_dinesh is offline
OC Issues sam9s Hardware Q&A 173 13-10-2008 03:31 PM
Broadband in Windows V/S Broadband in Linux.. Manshahia Open Source 3 30-05-2007 08:27 PM
Sleepy Broadband Idel Broadband Kaushal Hiwarkar Software Q&A 7 21-05-2007 11:48 PM
old issues bhrth QnA (read only) 4 16-07-2006 04:48 PM
POP issues saurabh.sauron Software Q&A 4 18-05-2006 04:16 PM
