Old 29-12-2008, 12:46 PM   #1 (permalink)
Wandering In Tecno Land
Ecko's Avatar
Angry XP Woes : Laggy System
Hi guyz I'm facing a strange problem
My XP windows lags before executing anything
I'm on C2D with 2 Gb DDR2 800MHz running in realtime Avast & ZoneAlarm Pro
Anything I double click isn't opened instantly but after few seconds as if system is jammed
All inputs appreciated
BTW i've tried all type of registry defrags & compressions & removing temp files
Even I've tried optimizing services but in vain
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
Ecko is offline
Old 29-12-2008, 01:25 PM   #2 (permalink)
I M A *STAR*
saqib_khan's Avatar
Default Re: XP Woes : Laggy System
Have u scanned with antivirus & antispyware, do a full scan.
And don't use zonealarm (My opinion) or remove it from startup & see what happens.
Blogging at:
Technostarry
saqib_khan is offline
Old 29-12-2008, 02:20 PM   #3 (permalink)
JojoTheDragon's Avatar
Try system restore if you are out of options. use COMODO firewall the best around now.
| Steam: jojothedragon | Origin : jojothedragon | PSN : jojothedragon |
TDF @ Steam
Get 2GB of free cloud space : http://db.tt/OJKPcZnY
JojoTheDragon is offline
Old 29-12-2008, 02:42 PM   #4 (permalink)
Wise Old Mouse
mrintech's Avatar
Clean system RAM
Remove Zonealarm and go for a scan with: http://www.superantispyware.com/download.html
- MrinTech :)
mrintech is offline
Old 30-12-2008, 12:01 AM   #5 (permalink)
Ecko's Avatar
Can't remove ZA guyz
Comodo is free but I don't prefer it because I'm not comfortable with it
Its too much advanced, with options messed up (Don't Mind)
I don't think with that amount of Ram on XP system there should be any problem
No virus is there checked all processes
Can I Monitor time taken by my processes ??
Ecko is offline
Old 30-12-2008, 11:30 AM   #6 (permalink)
y2j826's Avatar
disable some startup services from MSCONFIG and SERVICES.MSC
but only do if you are sure which one to remove
y2j826 is offline
Old 31-12-2008, 08:30 PM   #7 (permalink)
afonofa's Avatar
Lightbulb Re: XP Woes : Laggy System
Does the system lag even if ZAPro is shutdown?
You can try:
1. Set ZAP to receive program updates manually
(Overview > Preferences > Check for Updates > Manually)
2. Set ZAP AntiSpyware's automatic update to manual
(or set it to update automatically every 24 hours instead of the default 3 hours)
3. Turn off ZAP's realtime AntiSpyware.
4. Using a pirated key with ZAPro v8.x, causes some system lag. Try a genuine key.
afonofa is offline
Old 31-12-2008, 08:34 PM   #8 (permalink)
Try auslogics boost speed and view the tut forum and have a look on vishal gupta's thread.
TDF @ Steam
Old 02-01-2009, 07:47 AM   #9 (permalink)
Ecko's Avatar
You can try:
I think if I would have pirated this thing then I must have gone 4 full security suite rather than ZA pro
I uninstalled it & now using Kaspersky . Shear wastage of money grrrrrrrrrrrrrrrrr...!!!
Ecko is offline
Old 02-01-2009, 09:03 AM   #10 (permalink)
Just restore your system to the time when your pc was not laggy
TDF @ Steam
windows/system 32/ config/system files corrupted or missing ? mkmkmk Software Q&A 9 02-04-2009 02:55 PM
PC Woes godsownman QnA (read only) 1 16-05-2008 02:28 PM
Ubuntu...laggy & slow? adit_sen Open Source 16 29-01-2007 07:10 AM
My new system is running slower compared to my previous system! instinct Hardware Q&A 12 13-10-2006 12:57 AM
GroupPolicy is not apply on user and system in client system pr@k@sh QnA (read only) 5 07-09-2005 01:41 PM
