Old 24-12-2008, 01:04 PM   #1 (permalink)
Default drives are not opening
recently i fromatted my os and reinstall it after this i m facing a problem in my other two drive d nd e c is working well whenever i click to open one of them it shows an error message c:\resycled\boot.com is not a vailid win 32 application it happens when i click on a drive and try to open it when i open it through address bar it opens can any one tell me how to solve this problem i dont want to format it
tabish3 is offline
Old 24-12-2008, 01:09 PM   #2 (permalink)
Default Re: drives are not opening
As far as I remember, no folder named resycled is created by the default installation of windows XP. It seems your computer(may be windows setup) is infected with a virus. Scan for viruses.
ThinkFree is offline
Old 24-12-2008, 01:11 PM   #3 (permalink)
will it help me are you sure
tabish3 is offline
Old 24-12-2008, 01:19 PM   #4 (permalink)
http://www.microsoft.com/communities...&cr=&sloc=&p=1
http://www.computing.net/answers/sec...ild/23641.html
See if anyone of these helps
Old 24-12-2008, 01:41 PM   #5 (permalink)
thank buddy
tabish3 is offline
drives not opening.. ajooba215 Software Q&A 11 28-09-2008 08:51 AM
Drives not opening sravan Software Q&A 2 21-03-2008 05:25 PM
Drives Are Not Opening smile Hardware Q&A 3 12-11-2007 06:23 PM
drives not opening sharma_atul85 QnA (read only) 4 25-03-2007 10:35 PM
drives not opening Naveed Software Q&A 1 15-03-2007 08:51 PM
