| Forum |
#1 (permalink) |
PLZ HLP!!!! |
#2 (permalink) |
Wise Old Mouse
Go scan with:
* http://www.superantispyware.com/download.html * http://www.emsisoft.com/en/software/free/ Also use Avira as it is far better than AVG: http://www.free-av.com/en/download/index.html Don't forget to update the above softwares with latest definitions and also go for full system scan with each of the above |
#3 (permalink) |
AFK
Boot into safe mode and then scan your PC using your Antivirus.
Check out http://thefinal3rd.com, an Indian footie blog. Follow me on http://twitter.com/thewisecrab Fishdumplings!! Duniya goal hai? |
#4 (permalink) |
im had 1 like it a few weeks ago and it got on both hard drives i no ya cd drive dont work but the only way is format m8 i made a big mis stake by only formattin my first hard drive but wen itwas all done the virus was on my 2nd 1 m8 if u are gonna formatt give it a full format not a quick 1 cause the virus will still be there m8 let me no if u have any probs ok
#5 (permalink) |
15.0 GHz
dload HiJack This....boot u r pc in safe mode...run hijack this....remove all the components in it....restart the pc again in safe mode....and ask Vishal Gupta for removal of u r message task manager has been dis.....
PC(Intel Core2 Duo E4500 2.2GHz + Intel D946GZis + Dynet 2GB + 1GB DDR2 + 500GB WD Caviar + 250GB WD My Passport) iPod Touch 4th Generation - 64GB |
#6 (permalink) |
Overlord v2.0
To re-enable the Task manager, do this:-
Step 1:In the Start>Run box, type gpedit.msc and press enter. This will open the Group Policy editor. Step 2:Navigate to User Configuration>Administrative Templates>System>Ctrl+Alt+Del options using the left side pane. Step 3: Double click on "Remove task manager" entry in the main area. Step 4:Click on the "enabled" radio button and apply the changes. Step 5:Reboot! If this doesn't work or if Group Policy Editor is not present, Enter this in the run box(Start>Run):- Code:
REG add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System /v DisableTaskMgr /t REG_DWORD /d 0 /f Also, if you plan on running HijackThis, as suggested by Varad Dilip Choudhary, NEVER remove all that it shows! Save the log file and post it here for analysis.
The Only quote worth quoting: "E Loboa!!! What man??? Forum Rules:http://www.thinkdigit.com/forum/announcement.php?f=16&a=1 Disclaimer:No offence meant to ANYONE! |
#8 (permalink) |
It *was*. Not now. NOD32 3.0 is fu(ked up. 2.7 was the best. I hope it gets better with the new release.
Won't be replying to PMs for a while. Stay in touch with e-mail. Read before asking / messaging any moderator for any query: FAQ + answers for new members Read all the sticky threads before asking any type of query. Most basic questions are answered in those. |
#9 (permalink) |
Wandering In Tecno Land
I'm always safe with Avast Free Version & its Boot Time Scan
Born in Windows Die In Linux © 2009-10 All Rights Reserved. Learn Linux : www.linoob.com (Official WebSite) |
#11 (permalink) |
Boom Boom Boom
1. Restart ur computer and boot into Safe Mode
2. Delete AVG and other programs that seem unknown 3. Restart and boot once again into safe mode with networking 4. Download Avast or AVG 8 and run full scan 5. Disinfect everything it finds 6.Go here and run virus scan. 7. Remove manually what the scanner finds and restart again, this time into normal mode. 8. Delete CCleaner and download the latest version 9. Go to Microsoft Update here and install ALL updates
I'm back! Gimme a hugggggg... |
#14 (permalink) | |||
1. Run > gpedit.msc (Press enter). Group policy editor will appear. 2. User configuration > Administrative Templates > System > "Ctrl+Alt+Del Options" 3. Double click on "Remove Task Manager". 4. Disable this option (Yes, disable. If you enable this option Task Manager will be disabled) Quote:
1.cleanup all unwanted files 2.Do defragment remove not frequently used programs from start up. go to Run, type msconfig and click start up If not help give a screenshot of your Taskmanager Process Tab(All processess). i cnt use folder lock 2 open ma lockd folders n files See Here for faqs: http://www.newsoftwares.net/folderlock/faq.html Quote:
http://www.ccleaner.com/help/faq In The last install a good antivirus and antispyware, such as Avast(download latest avat and definitions from here) and adaware. Dont miss to register avast home and and Keep it always update: After installing avast and registeration, do this: 1. Right click on second icon and merge it. 2. Right click on main icon> Program setting> update connection>Check any of your suitable option. and close. Now your avast will update automatically always. |
#16 (permalink) |
GOD
always use avast free edition it is best. they have the updation two times a day.
unload ur antivirus and download avast new edition and install it and update its vps one time and schedule a boot time scan and restart ur pc. also click on the given link it is the free online virus checking by norton antivirus 2009. http://security.symantec.com/sscv6/WelcomePage.asp
Vaibhav Jain |
#17 (permalink) |
Thank u all 4 ur valuable inputs.... ma laptop ws cmpletly screwd... it jst wont open,,, nly d wallpapr gets displyd wthout d start bar wch i cudnt enable because task managr ws nt opnn... evn bootin int2 safe mode ws nt possible.. i got a blue screen sayn dat ma system is infctd... finally hd to bck up all d data n 4mat d entire hdd coz formattn jst d windows drive wont help.. i hd to do dis a couple of tyms coz d virus hd infctd all ma software setup files nd no antivirus ud detect it.. finally i got avast 4m a cd nd usin it i ws able to detect d infctd software setup files nd thus deletd all of dem nd formattd d drive agn,,, nw its runni fine.,,,,
4m dis experince i ud really say dat avast is better dan AVG,,, bt newys,, thnk u all guys |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| about a virus which attacked me,need guidence and giving info abt this virus-read | mobileman | Software Q&A | 2 | 16-11-2007 12:43 PM |
| Virus trouble (VERY weird stalker virus) | mightyboosh | Software Q&A | 9 | 22-08-2007 11:34 PM |
| Virus problem, need online virus checking details-pls hava a read here. | mobileman | Software Q&A | 2 | 14-04-2007 10:58 AM |
| mcafee virus scan 8.0 - problem updating virus definations | infra_red_dude | Software Q&A | 3 | 26-06-2005 11:43 AM |
| VIRUS...RANDEX ZEN.......VIRUS MLORE HELP..??URGENT | Writankar panja | Software Q&A | 9 | 19-09-2004 05:26 PM |
