Old 21-12-2008, 10:42 PM   #1 (permalink)
Default Dsl connection monitor software?
Hello everyone
i'm having bsnl data one connection has been disconnecting frequently
I need a software that will monitor my DSL connection and logs the time when it disconnect and reconnect, so I can get a pattern. Anyone know a good (preferably free, but if not...it's ok) software that can do that?
Regards.
marquee is offline
Old 22-12-2008, 10:09 AM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Dsl connection monitor software?
I think you can see details at some BSNL website only. Login using your account, and you can see all the usage details with timing.
ravi_9793 is offline
Suggest best connection analysing software. rkvic19 Software Q&A 1 08-07-2008 05:50 AM
Xubuntu - Network Monitor for GPRS connection sariq Open Source 3 15-11-2006 09:39 AM
question on adsl connection monitor and saving kde session infra_red_dude Open Source 2 30-11-2005 08:44 PM
freeware internet connection software kumarn_2004 Software Q&A 14 18-04-2005 03:41 PM
Small connection monitor ! What's the opinion. Ricky QnA (read only) 13 26-03-2005 02:37 AM
