Old 19-12-2008, 12:22 AM   #1 (permalink)
Question scheduling a system startup
Is there any way I can get my vista notebook to startup at a specified time?
I could find many applications on the web that allow a user to schedule a Windows shut-down, but not one that can get the system to start up on its own.
Any clues, or am i just asking a silly question?
technomad10 is offline
Old 19-12-2008, 06:11 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: scheduling a system startup
You can leave it on hibernate, and have apps to wake it up. If you want to wake it from a power down, you need to set it on the bios.
Use www.lifsoft.com to wake up from hibernate. Get a warez version.
dheeraj_kumar is offline
Old 20-12-2008, 09:15 AM   #3 (permalink)
thanks D.K.
Old 20-12-2008, 09:24 AM   #4 (permalink)
^^lol
which movie ? I remember DK was in Kya Kool Hai Hum may be
Steam/Flickr: psygeist
Asus Z68 V-Pro|i5 2500k|TRUE Black|Ripjaws X+Corsair Vengeance|U2311H|N560GTX|D7000|XONAR STX|RE272|RE0|CC51|XE200PRO Walnut| TD II V2| Ultraphile|N5800
Faun is offline
Old 20-12-2008, 09:41 AM   #5 (permalink)
@technomad
Do you know me or something? no one has called me DK in this forum before.
Old 23-12-2008, 07:55 PM   #6 (permalink)
I guess i shouldn't have abbreviated your name unless i really knew you, sorry if you're offended or anything.
Correcting System Hang at Startup ismart Tutorials 1 01-08-2007 02:53 AM
System Startup Problem............ satyamy QnA (read only) 3 13-02-2007 03:10 PM
system startup list...shall i remove all this ? mkmkmk QnA (read only) 2 07-05-2006 05:16 PM
Scheduling LAN yrana2002 Networking 1 27-11-2005 02:59 PM
Win XP : Disable MSN messgr frm System tray @ startup ax3 Tutorials 15 19-06-2005 12:30 PM
