Old 18-12-2008, 12:44 PM   #1 (permalink)
Unhappy Help Me for Problems after Virus-Cleaning
Hi Friends,
My PC got infected with a virus. I cleaned it, but now some features have remained disabled even after the cleaning process. I am using Windows XP SP2. For Example, Task Manager is disabled, Registry Editor is disabled, "Folder Options" menu is not appearing in Windows Explorer.
I created a new Admin account and it works fine without any issues like above-mentioned.
How can I change these options back to "Enabled" settings? Please please help me.
Also, please tell me if there is any way to disable / password protect the use of USB mass storage devices. I need this to do very desperately. I followed the Miscrosoft's article on disabling USB drives, but it does not work on my PC. When I select properties of "Usbstor.pnf" file, there appears only "General" tab , no "Security" tab and nothing.
ThanQ in advance
ispote is offline
Old 18-12-2008, 01:13 PM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Thumbs up Re: Help Me for Problems after Virus-Cleaning
I think this thread can help u.
[Windows] FreQuently AsKed ProBlems WITH SoluTions...
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is offline
Virus problems Flashbang Software Q&A 4 12-12-2008 01:06 PM
cleaning pc temperworld QnA (read only) 8 17-08-2008 02:04 PM
DVD Cleaning? User Name QnA (read only) 6 22-12-2007 09:55 AM
CPU Cleaning Charan Hardware Q&A 18 17-10-2007 12:52 PM
