Go Back   Digit Technology Discussion Forum - Tech Discussion Forums in India > Software > Software Q&A
Have you tried the new Digit
Old 15-12-2008, 12:43 PM   #1 (permalink)
himadri_sm's Avatar
Default Computer Management does not open
when i try to open computer management (from control panel- administrative tools- computer management) i get this error message-
C:\WINDOWS\system32\compmgmt.msc
access is denied
i scanned my pc for viruses & spyware but found nothing..overall my pc is running fine.
how do i open computer management now? i have to delete some partitions in my hdd!
access is denied
why isn't anyone replying? i searched using google but can't find a solution..even gpedit.msc doesnot open..the same error message- access is denied.
himadri_sm is offline
Adobe
Old 17-12-2008, 08:12 AM   #2 (permalink)
Amir.php's Avatar
Default Re: Computer Management does not open
1. Open Registry Editor (regedit.exe on run dialog box).
2. Now goto to
HKEY_CLASSES_ROOT\.msc
and delete the registry entry on the right side.
3. After deleting it when you again type gpedit.msc in Run box, it will open an “Open with” dialog.
4. Now select the second option and browse to get a new option; browse to
C:\Windows\system32\mmc.exe
5.Select this option and remember to check the box below to always run the command without doing this again and again.
6.That’s it, Now all .msc extensions will now open. A new option “Microsoft Management Console” will appear in the window.
Amir.php is offline
Old 17-12-2008, 11:36 AM   #3 (permalink)
himadri_sm's Avatar
2. Now goto to and delete the registry entry on the right side.
thanx for replying..but this can also be done through windows explorer->tools->folder options->file types->msc->opens with->c:\windows\system32\mmc.exe (searched google as no one was replying for a long time)
can't open any google site from my computer using any browser dip_10 Software Q&A 5 29-11-2008 07:48 AM
Open the System Properties Dialog Without right click on my computer Masroor Tutorials 2 25-10-2007 09:38 PM
how to disable computer management sridatta Software Q&A 4 14-10-2006 02:10 PM
My Computer Drive Open Error adit_sen QnA (read only) 19 12-10-2006 11:07 PM
GMail refuses to open in my Computer --- Urgent Help needed Tech&ME Software Q&A 10 06-01-2006 09:48 PM
Upcoming Events
Think diget
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
