Old 14-12-2008, 08:38 PM   #1 (permalink)
Default sound problem in xp
hi guys i am using window xp sp3...suddenly my creative 1.1 speaker gone kaput...they are not producing sound
i have noticed following three thing
1.in control panel its showing no hardware is connceted
2.these speaker work with other mp3 player but with very low sound
3.when i plugged in head phone i too didnt get any sound from them
i have reinstalled window+driver but problem is still there...what to do
what to do
ashishstillthere is offline
Old 15-12-2008, 09:34 AM   #2 (permalink)
vagish's Avatar
Default Re: sound problem in xp
Hi.
This may the problem of Hardware.
If you are using the External Sound card, please remove and place it on the other slot. This is because of loose connection.
If Sound card is Inbuilt with the Motherboard, then it seems that the its a motherboard problem.
vagish is offline
Old 15-12-2008, 09:41 AM   #3 (permalink)
sound card is inbuilt so how to rectify it???
Sound problem with VLC 0.8.6d chicha QnA (read only) 8 31-03-2008 07:50 AM
Problem with the SOUND of CPU fan rahul123wagh Hardware Q&A 3 28-11-2007 01:01 AM
Sound Problem with Nvdia onboard Sound (hda-intel) Maverick340 Open Source 4 18-09-2007 11:12 PM
sound problem jmit QnA (read only) 3 07-05-2006 06:46 PM
Sound Problem zodiac_511 QnA (read only) 11 28-08-2005 10:05 PM
