Old 13-12-2008, 11:55 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
win2k intrnls xpert
Smile How to get product id for original xp disc ?
Please,how to get product key for original xp disc?
I have an original XP OEM (I got it from a telecom company's office.Please don't ask abt
the sources.I am not sure if its OEM or not) CD.The people who gave me have also left
the place.Its from an HCL PC.
Is there anway of obtaining the product key for this CD?
On the CD there are this values :
0601 part no.X08-33951
On the CD cover the Certificate of Authenticity[ (COA) or whatever it is called ]
has this number wriiten on it :
00045-136-258-884
The booklet or manual that comes with the original CD has these values:
On th back of the booklet.Actually there are two stickers.
1.is the same as that on the CD cover has this number written on it:
00045-136-288-942
2.Another sticker which states as below:
"The COA label has been removed by your PC manufacturer and should be attached to your PC." ???????
Can I get the Product key from these numbers? Will Mcrosoft Product Support be of
any help in obtaining the Product Key?
I don't know if it is illegal to do this .So need expert advice from members here.Please
Hell is the impossibility of reason.
mannrak2003 is offline
Old 14-12-2008, 12:05 AM   #2 (permalink)
Wise Old Mouse
mrintech's Avatar
Default Re: How to get product id for original xp disc ?
The product key must be on the Cover itself. Check again.
- MrinTech :)
mrintech is offline
Old 14-12-2008, 12:26 AM   #3 (permalink)
win2k intrnls xpert
@mrintech
Its just a plain white paper cover,with transparent plastic attached to the front side..on
the back side which is wholly paper is the COA label or whatever it is with the number
I mentioned previously ie,00045-136-258-884,thanks.so please,any way of obtaining
Product Key for this CD?I can't go back to the office of this company for the key.I think
the COA attached to the back of company PC cabinets show the Product Key.But I'm
not sure on which particular machine this version of XP on my CD is installed,Thanks
Old 14-12-2008, 12:48 AM   #4 (permalink)
Wise Old Mouse
mrintech's Avatar
I am assuming that you have original Windows and also i am assuming you have missed your product key. So legally you can use what is written below:
In order to view your product key you have to install the OS on your system and than use: http://www.webtechgeek.com/How-to-Fi...roduct-key.htm
Otherwise use: http://support.microsoft.com to retrieve your OS key from details that you gave.
- MrinTech :)
mrintech is offline
Old 14-12-2008, 02:14 AM   #5 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Magic Jellybean XP Key finder. AVs detect it as a virus but its a false alarm.
dheeraj_kumar is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/software-q/104349-how-get-product-id-original-xp-disc.html
Thread How to get product id for original xp disc ? | Digit Forum | BoardReader This thread Refback 02-08-2010 08:17 AM
Please insert the original disc NIGHTMARE Gamerz 13 12-01-2007 09:20 PM
new product ? shreyadr QnA (read only) 2 28-12-2006 09:51 AM
What is OEM product and Boxed product jamesbond007 Hardware Q&A 9 06-12-2006 07:24 PM
Product key abhi_10_20 QnA (read only) 8 04-09-2006 07:22 PM
