Old 13-12-2008, 08:42 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
ayushman9's Avatar
Exclamation How to increase upload speed in utorrent ?
I have been using utorrent for about 1 year now . According to speed test my speed is 1875kb/s dl & 200kb/s up ( kb = kilobits )
Now i have recently started to use private trackers ,the thing is my download speed is ok in fact more than ok it sometime reached about 300kb/s ( 300 = kilobytes ) ,but the upload speed reaches only up to 2 to 5 kb/s . I have been banned from a respected tracker for violating the ratio policy but i don't know how to increase the upload speed as was not keen in past to seeding task .
I also changed to static ip ( using some online tutorial ) ,& it resulted in increase in download speed but my upload speed is still low . Please help ? Ho can i max out my uploads speed ?
There is No Dark & Light side of Force . There always has been,always will be & always has been,One & Only Ayushman
ayushman9 is offline
Old 13-12-2008, 11:43 AM   #2 (permalink)
pushkar's Avatar
Default Re: How to increase upload speed in utorrent ?
You are getting low upload speed because you are snatching old torrents which have high seeder leecher ratio. Things are different on private trackers. Unless you jump on new torrents quickly, you won't be able to seed back much, because the torrents already have high amount of seeders compared to the leechers. So the only way is to jump on new torrents when there are many leechers and less seeders. And beware of packs. You may find many packs with huge amount of leechers, but they are mostly partial seeders. As they don't have the full downloaded content, they show up as leechers, but they are actually seeders.
And whatever you grab, seed it for a long time.
BTW, I didn't understand how you changed to static IP using an online tutorial. Static IP is given by the ISP, isn't it?
pushkar is offline
Old 13-12-2008, 06:02 PM   #3 (permalink)
ayushman9's Avatar
Wink Re: How to increase upload speed in utorrent ?
no actually i haven't changed directly into static ip ,but it is more like that now my status is being shown connecteble ,this i did by port forwarding ,so actually i should have told that i had port forward the utorrent
by the way i did not understand your explanation ,i am currently downloading from a new torrent ,the download speed is awesome but upload reaches only upto 2 to 3 kb/s ,however i have seen sometimes that upload speed reaches upto 10 to 12 kb/s .That is pretty good ,so i am asking how can i make that because the speed remain only for minute or two ,it again fall back to 2 to 3 kbps . I even bandlimited my download rate to 5kb/s but no avail .Is theer any special setting that i may have gone wrong ?
Old 14-12-2008, 02:10 AM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Bandwidth>Change global max upload speed to 0, and download speed to 0, Max connections to 10000, no of peers = 500, upload slots per torrent = 10, check the bottom box
Bittorrent>check all boxes except local peer. choose enable encryption
Queueing>first box = something high, your no. of torrents say 10
Those are perfect settings for high upload speeds. Also check the increase torrent speed thread in tutorials subforum. So you need to increase tcp half open window size etc...
dheeraj_kumar is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/software-q/104300-how-increase-upload-speed-utorrent.html
Thread Increase upload speed in uTorrent | Mac Forums - Mac News and Rumor Discussion | BoardReader This thread Refback 14-04-2011 03:32 AM
How to Make Torrents and Upload them using uTorrent? Plasma_Snake QnA (read only) 9 14-05-2008 10:56 PM
Unable to set upload speed limit in uTorrent sandeepk Software Q&A 1 15-01-2008 11:29 PM
Help - I want to decrease upload and increase download gauravsuneja Internet & WWW 2 07-01-2008 09:15 AM
utorrent prob, upload speed is higher than download speed daemon Internet & WWW 2 17-07-2007 03:05 PM
Anyway to Increase Upload speed in BSNL... hmmmmmmmmmmmmm Broadband and DTH 4 09-10-2006 08:10 PM
