Old 09-12-2008, 10:29 AM   #1 (permalink)
Question startup problem with vista
hi everyone i m using vista n in last week i hv installed a engineering software named caesar 2 on my laptop but unfortunatly it wont work...
so i removed it frm controll panel and delete all files frm program files folder.
n now every time i on my laptop a setup file run which says "gathering files for caesar2" after sm process it goes off . i want to know how to stop it permanently...
plz help me..........
sushantsaurabh is offline
Old 09-12-2008, 10:51 AM   #2 (permalink)
paroh's Avatar
Default Re: startup problem with vista
1)search the file in ur Pc and delete that file
2)Go to run->msconfig->startup see the entry for that file and un-check it.
and restart the pc to check whether it works or not.
3)run->regedit->search for that file and delete its entry from the registry
paroh is offline
Weird Win Vista startup problem Shikhar Software Q&A 4 05-11-2008 11:30 PM
Vista problem . . White screen and slow startup phuchungbhutia Software Q&A 1 03-08-2008 03:35 PM
Startup problem in VISTA!! mad_hatter_11 Software Q&A 5 21-03-2008 12:27 AM
startup in vista saubrl Tutorials 1 06-12-2007 10:23 PM
