Hi guys,
I'm using Windows Vista Ultimate with 1GB RAM and a Dual Core processor.
Yesterday evening when there was a power cut my UPS didnt function, so my system abruptly switched off..
Then when I switched it on today I was welcomed with the login screen, but when I clicked my user account there was only a black screen along with a mouse pointer. I opened the Task manager using [ctrl] + [shift] + [esc] I found that explorer was not loaded. So I selected "New Task(Run..)" then opened Explorer. Unfortunately it ran in vista basic theme. When I checked the theme dialog I found that there were only the basic versions of some 2 or 3 themes installed. And also after this chaos none of the videos play, i.e. I dont get the video but only the audio (I tried all the possible players VLC, Media Player Classic, WMP... etc but its the same). I tried restarting the computer, restarting in safe mode, restarting in "Last known good configuration" mode, but its the same black screen with a mouse pointer.
I use NOD32 anti-virus, and when I scan the full system for virus, after some 3 or 4 mins I get a BSOD, I get the same BSOD even when defragmenting the drives(tried defragmenting using both default MS defragmenter and also Disk Perfect software)
I tried chkdsk, "Scan disk for errors" option in the partition properties dialog, sfc /scannow option in cmd also, they all showed no errors. I also tried the memory test in the boot screen of vista even that showed no errors.
Please help me gurus..
Thanks in advance.
__________________________________________________ ________________________
no one knows the solution??
guys.. Please help me out.
