Folks which amongst the 3 file sync programs below would meet the criteria of ease of use, reliability, stability and features like incremental bakups, support for ext media etc.
1. Sync Back
2. Vice Versa
3. Allway Sync.
Would be grateful and appreciate it if you could share your experiences with the above or any other software that you're using. Thanks a mill.
