Re: AMD Turbo C problem!
U should check that & install , "DONT USE THE AMD TURBO C PROBLEM"
Does AMD created the turbo C??
Anyway check your OS and installation process .
"use the BORLAND c/c++ to fix your problem" this will run safe.
never use the processor for the issues like this
Reason: Automerged Doublepost
