Old 05-12-2008, 02:08 AM   #1 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Default VCD size problem cant copywrite.
Now most of VCDs are coming with 700+ size so cant copy write with nero.The dat files in the cd also r more than 700 even in 700mb cd.I opened the cd in isobuster it showed the same file size to 634 and i extracted it but after extraction the changed to 700+ again.i know it is fake size but only solution i hav is to cut short the video and encode to lower bitrates.but the process is tough and lengthy.
So i need an another simple solution.
PLS HELP...
ajai5777 is offline
Old 05-12-2008, 12:51 PM   #2 (permalink)
It doesn't matter!
Sumeet_naik's Avatar
Default Re: VCD size problem cant copywrite.
You can burn a 80 mins of video in a 700 mb discs.. And 90mins on a 800mb discs..
Twitter - http://twitter.com/Sumeet
Blog - http://sumeetnaik.blogspot.com
Lenovo Y410 775787Q + SE K530i
Sumeet_naik is offline
Old 05-12-2008, 01:28 PM   #3 (permalink)
Wise Old Mouse
mrintech's Avatar
cut the first and last titles
- MrinTech :)
mrintech is offline
Large Image files Size to Small Images Size. Charley QnA (read only) 14 03-03-2007 01:19 PM
What is maximum size of .pst file in microsoft outlook And Can I increase .pst's size fazle Software Q&A 1 25-02-2007 11:53 PM
Size Problem With Movies In DVD5... go4saket QnA (read only) 1 21-05-2006 11:35 PM
Page size problem in this Forum... go4saket Internet & WWW 2 12-12-2005 06:28 PM
problem on screen size!!!!!!!!!!!!!!! alaap_anujan QnA (read only) 1 10-11-2005 06:13 PM
