Old 05-12-2008, 12:35 AM   #1 (permalink)
Always friendly as DIGIT
binilmb's Avatar
Default No Video - Different Problem
Hi Everybody,
I have faced a different problem in one of my friend's PC. The problem is that the system doesn't play any type of videos in it. When we want to play any video files(*.avi, *.mpg, *.dat, *.vob etc) in any players like WMP11, Media Player Classic(K-Lite Mega Codec Pack), VLC, Power DVD etc they only plays the sound, video doesn't shown. What was the reason for this ? Plz reply quickly plzzzzzz............
binilmb is offline
Old 05-12-2008, 08:35 AM   #2 (permalink)
paroh's Avatar
Default Re: No Video - Different Problem
Video codec try to install ffdshow codec.
Install ur video card drivers again(first uninstall the old one then install the new one the latest one)
Also check that Directdraw acceleration and direct3d acceleration are enabled to check this go to run->dxdiag->display
paroh is offline
Old 05-12-2008, 10:51 AM   #3 (permalink)
parthbarot's Avatar
Check drivers first...
install drivers properly..which will include directX also...
then install Klite mega codec pack/VLC player...which should play your videos.
regards.
www.techlads.com
Paarth.
parthbarot is offline
Old 05-12-2008, 11:21 AM   #4 (permalink)
Wise Old Mouse
mrintech's Avatar
Try: http://www.gomlab.com/eng , check for drivers (reinstall if necessary) and also get the latest version for k-lite
this also happens when you download video files from Internet and the files are broken somehow
- MrinTech :)
mrintech is offline
problem in video playing Shloeb Software Q&A 1 02-12-2007 07:11 PM
video out ( s-video connector) problem blackleopard92 Hardware Q&A 2 08-01-2007 10:34 AM
Video Capture problem. Plz Help. Max_Power Software Q&A 2 20-01-2006 09:37 PM
Video rendering problem!-in ULEAD VIDEO STUDIO nithinks QnA (read only) 1 02-08-2005 06:52 PM
no video problem rakee Software Q&A 1 18-05-2005 02:54 AM
