Old 03-12-2008, 11:02 AM   #1 (permalink)
Cool Buddy's Avatar
Default desktop not showing
I re-assembled my old computer a few days back. It is working fine but the explorer (taskbar, start menu, desktop) is not loading. I've to load it manually from task manager every time I start the compter. it uses windows xp.
everything else is fine and it doesn't have a cd/dvd drive. for both these reasons I don't want to reinstall windows. what could e the problem?
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
Old 07-12-2008, 10:30 AM   #2 (permalink)
JojoTheDragon's Avatar
Default Re: desktop not showing
Had a same problem once with vista due to using a crack , go for a genuine version with the original Cd. Or reinstall the OS. GENUINE USERS DON'T FACE THIS PROBLEM
| Steam: jojothedragon | Origin : jojothedragon | PSN : jojothedragon |
TDF @ Steam
Get 2GB of free cloud space : http://db.tt/OJKPcZnY
JojoTheDragon is offline
Old 07-12-2008, 01:24 PM   #3 (permalink)
Amir.php's Avatar
insert your Xp CD in drive and choose upgrade.
This will recover all your missing files.
Amir.php is offline
Old 07-12-2008, 01:34 PM   #4 (permalink)
Cool Buddy's Avatar
Good one. But if you read my question properly, its an old computer which I might use just for playing some music or downloading stuff with night unlimited connection (which I don't have yet). I can't afford to buy a multi user license for such a pc. I should have been able to use one xp cd with 2 computers, afterall I don't need to take multiple electricity connections for separate rooms, then why software?
Nokia 5230 :(
Old 08-12-2008, 01:30 PM   #5 (permalink)
I think system restore should do the trick. Any way iam using ? version of vista
TDF @ Steam
Old 08-12-2008, 11:10 PM   #6 (permalink)
Dr.tweaker's Avatar
insert your xp disc,go to run,type sfc/scannow .probably this will fix it
Nokia X6
Nokia E5
Dell Inspiron 15"(Dun fu**in really care bout the suffix,does my geeky chores,that's it)
a 500 GB (priceless,every bits of it) music repo.
Gold Flake,OMR
Dr.tweaker is offline
Old 09-12-2008, 12:10 AM   #7 (permalink)
Linux all the way
how about adding explorer.exe to scheduled tasks, each time you boot your PC.
may be that can solve your problem, though never encountered sucj prob.
At times life takes a U turn and you get back where you were...
Vishal Patil is offline
Old 09-12-2008, 06:03 PM   #8 (permalink)
Cool Buddy's Avatar
exlporer does start but does not work unless I end the process and restart it by typing explorer.exe or userinit.exe. I added userinit.exe in startup but that also did not work.
Anyways, now that I've plugged the smps of that PC into some other PC, i won't be using that any more. so thanks for helping.
Nokia 5230 :(
Desktop icons not showing manishjha18 Software Q&A 7 02-07-2009 06:30 PM
windows xp desktop showing blank screen on logon bsrinivas Software Q&A 1 10-06-2008 08:21 PM
how to lock desktop so no files saved on desktop ranjan2001 QnA (read only) 8 22-03-2008 08:32 PM
[Desktop Screenshots] The Official April 2006 Desktop Thread Nemesis Chit-Chat 53 11-08-2007 12:29 AM
Customize Desktop missing from right click on desktop krazydude QnA (read only) 4 24-07-2005 12:47 PM
