thiis is my first post here....
i need help in installing javasdk on my linux opensuse 8.0
i have the bin file, followed instructions on the net and installed in /usr/java directory.
now comes the problem of setting the environment variables::
wen i set d environment variables it runs perfectly n java compiler is detected, but on restarting the gnome terminal it again gives the error:
javac:command not found.
wat is to be done in order to not to set the environment variables again n again before compiling a .java file.
if someone has successfully installed javasdk on a linux system, please be kind enuf to tell the procedure in little bit of detail...
thanking in anticipation:::
