Old 28-11-2008, 03:48 PM   #1 (permalink)
Default My C drive space problem
I HAVE FORMATTED SYSTEM PARTITION WITH ONLY 6.15 GB. That is enough for my 20 GB HDD. XP Pro with SP2 installed on that drive but space problem sucks. Now only 200 MB left. What I'm gonna do?
Is there any software that can show where the space has been used? 'Cuz I have already moved my "Temporary Internet Files on E:\. My all programs are on D:\. Page file is again on E:\
I frequently delete Temp folder.
Now what else I can do?
snehit is offline
Old 28-11-2008, 04:37 PM   #2 (permalink)
Default Re: My C drive space problem
Move My Documents folders too to other partition if u haven't done it so far.
You can reduce the amount of space reserved for system restore points and recycle bin on C: to get some more free space. Run CCleaner and Windows disk free up utility as well.
ThinkFree is offline
Old 28-11-2008, 11:10 PM   #3 (permalink)
Extheist
aditya1987's Avatar
Turn off system restore for C: dirve.
Meowww......
aditya1987 is offline
Old 28-11-2008, 11:18 PM   #4 (permalink)
move your pagefile to another partition and next do what above posters said
Faun is offline
Old 28-11-2008, 11:23 PM   #5 (permalink)
Extheist
aditya1987's Avatar
He has already said that the page file is in E: drive.
Meowww......
Old 28-11-2008, 11:45 PM   #6 (permalink)
^^oops
Faun is offline
Old 29-11-2008, 12:22 AM   #7 (permalink)
Wise Old Mouse
mrintech's Avatar
Turn off any sort of System recovery/backup Monitoring software.
- MrinTech :)
mrintech is offline
Old 03-12-2008, 08:06 AM   #8 (permalink)
Why don't you add another HDD to your system? HDDs are cheaper nowadays.
rose tamang is offline
Old 03-12-2008, 09:05 AM   #9 (permalink)
Hi, rose tamang
Of course! that is there but what is solution for now. I am not going to waste my number of hours to install all the applications. Dude !!!! In fact, I already have 500 GB external drive. So only problem of space is for system partition.
snehit is offline
Old 03-12-2008, 09:53 AM   #10 (permalink)
unni's Avatar
If you regularly update Windows XP, you can go to C:\Windows folder and delete all folders named like "$NtUninstallKB954459$". I used to regularly do this when I was using Windows XP. The only problem in deleting these is that you won't be able to roll-back (uninstall) any of the updates.
Another issue that I used to face was with AVG. In my Windows XP system, one AVG folder (I think the path was C:\Documents and Settings\USER\Application Data\AVG) used to become huge (sometimes reaching 4-5 GB) after updating. I used to delete all the files in that folder.
If you have Windows Media Center and record programs from TV, you can delete those recordings. Also, I have seen some times Nero Vision leaving the temporary files if I cancel an encoding.
You can also disable hibernation if it is enabled.
If there is no other way, I suggest you to increase the partition size using Acronis Disk Director. I think one of the magazines (like Digit) gave Paragon Partition Manager full edition for free during the last or previous to last month. I haven't used it, but may be you can try that as well. I used GParted for resizing my 250 GB Vista partition which came with my laptop for installing Ubuntu.
unni is offline
Old 03-12-2008, 10:57 AM   #11 (permalink)
Cool Buddy's Avatar
try disk space explorer
go to start>run and type %temp% see if there are any big files over there. generally when a program is installed it is extracted to this directory first and the temporary files are not deleted after installation. Sometimes this folder can get very huge.
for instance I just checked whether %temp% was the right thing or not and noticed that it was 1.84 GB on my PC
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
Old 04-12-2008, 10:44 PM   #12 (permalink)
AFK
thewisecrab's Avatar
Run CCleaner, disable System Restore for that drive.
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Space in C: Drive shyamno Software Q&A 29 21-12-2007 02:05 PM
low space in Drive C qadirahmed QnA (read only) 8 29-08-2007 11:42 PM
Adding space to OS drive ComputerUser QnA (read only) 2 17-07-2007 08:18 PM
c drive out of space... shreyadr QnA (read only) 2 01-03-2007 06:06 PM
How to free up some space in C drive? tamilvendan QnA (read only) 13 24-11-2005 11:13 AM
