Old 27-11-2008, 04:17 PM   #1 (permalink)
TheHumanBot's Avatar
Exclamation Need Help Ghosting XP SP3
Hey,
I Have a so many queries on this subject.
First thing is Installing Fresh Copy of XP is very painful.
after that update it again and Installing other softwares.
and if the softwares are genuine so you have to surrender licenses and reactivating
it again. (like i have XP, Adobe, Kasper anti and Tally Multi)
there is any way to create a Fresh Installed C:/
( i can install other adobe,kaspersky and tally after Fresh XP Installing no problem)
I have tried many Imaging softwares but not Satisfied...
Make a Image of C and Restore it again. . . not possible (not in my case)
I have only 80 GB cant giving a whole partition for Imaging if Temporary
need it i can adjust . . .
I have tried ones to create XP SP3 with Ghost 12 but what happened???
All the partitions are Deleted and Left c: as Unknown Format
(cant get the info of c: its NTFS, FAT32 or what type it is and lost HDD 320GB Hitachi)
I have lost my Music Collection and my working data . . .
so if anyone can guide me to exact way to do this will be appreciated
or anyone to interested to create one for me and courier it to me
( i will pay for CD).
I have tried google search but all are fakes not find a exact tutorial.
Please Help me for Tutorials or any kind of Info you can give.
IN SIMPLE WORDS I WANT A CD OF XP SP3 WHICH CAN INSTALL
XP IN LESS THAN 4 MINUTES.
TheHumanBot is offline
Old 27-11-2008, 05:08 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Need Help Ghosting XP SP3
Download SP3 for XP offline setup.
http://www.microsoft.com/downloads/d...displaylang=en
Run it after you have installed win XP SP2
ravi_9793 is offline
Old 27-11-2008, 05:14 PM   #3 (permalink)
dude i want tutorial not sp3
i already have genuine
Old 29-11-2008, 07:09 PM   #4 (permalink)
Thumbs up Re: Need Help Ghosting XP SP3
You could try the driveimage XML plug-in along with a BartPE bootable CD. Also, you say that you don't have enough harddisk space. So install only those software that you absolutely need. If you have more than 256 MB of RAM then before you create the backup disable pagefile on all drives. Boot using Bart PE and delete the "pagefile.sys" and then backup your drive. You could even move the target location of "My documents" to some other partition. Hope this works for you.
arun181818 is offline
GHOSTING a System mr_fanatic Internet & WWW 8 02-06-2007 11:35 AM
Best Ghosting Sofware for Download sainit Internet & WWW 1 04-07-2006 03:26 PM
