Old 25-11-2008, 06:26 PM   #1 (permalink)
Default Correcting how?
Hi,
I have got Windows XP Home Edition (SP2). It is already on C. But I installed again the same software on D. But I formatted D. 1). But I do not know how to remove it completely.
Moreover, using the CD for the purpose of remove it, I once again installed ONLY the set up of the software unfortunately without completing the whole process of installation. 2). How to delete Windows XP Home set up too?
So, when booting, there are on the screen as follows:
Windows XP Home
Windows XP Home
How to solve it, step by step?
kumarn_2004 is offline
Old 25-11-2008, 08:02 PM   #2 (permalink)
Ishan's Avatar
Default Re: Correcting how?
boot from any one of the first two OS....whichever u want to keep
and remember the choice.
now edit the boot.ini of this OS and remove other entries from it... and check to wich drives other OSes entries point to..
Format these Drives or just delete the windows related folders
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Old 25-11-2008, 09:06 PM   #3 (permalink)
PhB
Jughead!!!
PhB's Avatar
1. Boot from the windows you want to keep
2. Goto c:\
3. Open boot.ini
4. If you can't see it, run > boot.ini
5. Delete those entries pointing to the unwanted windows.
6. Delete the unwanted files.
7. End
PhB is offline
Old 26-11-2008, 09:14 AM   #4 (permalink)
gkbhat.blogspot.com
Goto start ->run
Type msconfig
Goto boot.ini tab and click check all boot paths twice .
Hope this will solve the problem.
blogging at http://gkbhat.blogspot.com
gk2k is offline
Old 26-11-2008, 06:31 PM   #5 (permalink)
AFK
thewisecrab's Avatar
@thread starter
Use better titles for more replies. Most senior members just overlook vague titles.
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Correcting System Hang at Startup ismart Tutorials 1 01-08-2007 02:53 AM
